Aprilaire 600 Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 09:13 PM   #1
Good evening. Hoping for some help with the wiring of my new Aprilaire 600. I've attached a picture of the wiring diagram as well as a picture of my furnace circuit board and the humidstat. According to the wiring diagram there are five connections on the circuit board that need to either be routed through or continue to the humidstat. The first one 'R' is easy ('R' to 'R'). 'G' (green wire) should be removed from the circuit board connection and routed to the 'G' on the humidstat. The 'G' connection on the circuit board is then connected to the 'Gf' on the humidstat. The 'W' on the circuit board is easy ('W' to 'W'). I have two issues I'm not sure of. What does the 'C' on the diagram refer to? Also, what is the point of the transformer?
Any help would be greatly appreciated. Thanks.
gilbo125 is offline   Reply With Quote
Old 01-31-2014, 05:25 AM   #2
An old Tradesmen
Rewards Points: 6,112
C, is common. The c of the humidistat must connect to the C of your furnace board. Needed o power the humidistat. Your furnace board should already have a wire from the A/C connected to it.
The transformer is to actually power the humidifier/open the solenoid valve. Helps to prevent over loading the furnace's transformer.
Old 01-31-2014, 05:36 PM   #3
All done.
Old 01-31-2014, 06:06 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
looks good. I always like hard pipe better than that plastic flex stuff they give you, gets better airflow.
The Following User Says Thank You to yuri For This Useful Post:
gilbo125 (01-31-2014)
Critique my Panel Wiring Please Ocelaris Electrical 14 03-16-2013 02:10 PM
Extending Wiring Before Circuit Panel... Zeigh Electrical 3 03-02-2013 08:36 PM
Aprilaire 700 Wiring tysonmj HVAC 2 01-31-2011 06:48 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
