Aprilaire 500a Install - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2014, 12:08 PM   #1
Rewards Points: 164
Aprilaire 500a install
So I'm installing a new aprilaire on my furnace and the tiny install sheet makes a passing note to install the bypass past the ac coil...however due to my low ceiling and duct work, the ac coil is as high up as it goes. The question is if I install the bypass before the ac coil will it cause any problems? The ac coil gets wet anyhow so I'm having a hard time seeing what problem this could cause.
ryan50hrl is offline   Reply With Quote
Old 11-26-2014, 12:10 PM   #2
Rewards Points: 164
Planned install
Old 11-26-2014, 02:14 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
Put it below. No Problema. I did mine that way.
Not sure why they mention that. However you do not want to leave the bypass damper wide open as there is LOTS of pressure there and it could blow the water off the pad. I throttle mine 1/2 closed. Just need enough air to cross the pad and have enough time to pickup the moisture.
Old 11-26-2014, 05:15 PM   #4
An old Tradesmen
Rewards Points: 8,202
They usually tell you above. So you don't mount it level with the coil, and drill a hole in the coil in the process.
Below the coil is fine.
Old 11-26-2014, 05:34 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
Was there myself. Had a customer drill a hole in his coil and blow all the Freon out. Had to patch it and recharge. Not a cheap job.
Must of scared the heck out of him when it blew.
Old 11-26-2014, 05:53 PM   #6
Rewards Points: 164
Well.....you can't fix stupid....seems like common sense would be to check what's behind where you're drilling.
Old 11-26-2014, 06:54 PM   #7
An old Tradesmen
Murphy's law is more common then "Common sense".
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 08:36 AM
New deeper kitchen sink install problem jmalcolm Plumbing 3 04-27-2011 10:48 AM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 02:18 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
