Aprilaire 500 Install Help - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 09:26 AM   #1
Rewards Points: 81
I am installing an Aprilaire 500A whole house humidifier on my Carrier Weathermaker 8000 forced air unit. I have everything installed and I'm ready to do all the wiring. The model 60 control that I got is different than all the ones ive seen before. Instead of 10 screw terminals, this one has 11 with an additional Gf terminal. I could hook it up the way the instructions show, but it seems considerably more complicated than it needs to be. My furnace happens to have the HUM and COM points which should make this a breeze - can I use these instead of the goofy instructions they provide? What terminals get connected?
As a side question, on my furnace I noticed a second 18/2 line coming in and connecting to the Y and COM terminals but I dont know where it goes. It is not the thermostat wire and I have no other controls - could this be going outside to the A/C unit?
BaconK5 is offline   Reply With Quote
Old 12-05-2012, 09:29 AM   #2
Rewards Points: 81
This is the control board from my unit. Note the extra 18/2 line coming in to the Y and COM
Old 12-05-2012, 01:30 PM   #3
HVAC Tech/Owner
Rewards Points: 604
"extra line" is noted....looks like the AC control power to me
Technow is offline   Reply With Quote
Old 12-05-2012, 01:40 PM   #4
Rewards Points: 81
I checked in with Aprilaire and got it straightened out. They changed the way the solenoid terminals work and the default instructions are setup for blower activation. To remove the blower activation I just need to swap a couple of wires.
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 01:35 PM
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 09:36 AM
New deeper kitchen sink install problem jmalcolm Plumbing 3 04-27-2011 11:48 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
