Aprilaire 400 Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 10:04 AM   #1
Aprilaire 400 not working
Hi folks,
I have an Aprilaire 400 connected to my HVAC/forced air heating unit which doesn't seem to be working. I've tried the following:
- Followed instructions from Aprilaire to test/check the humidistat. I hear the clicks, but don't see any water coming out.
- Changed the water panel, however the humidistat 'change water panel' light is still on (see attached picture)
- checked the water pipes and pump but see no obvious problems.
I live in Long Island NY, and the inside humidity is 25% irrespective of the outside humidity.
It'll be great if any DIY experts can let me know if I can do anything else before calling a professional to look at it.
Thanks in advance for your help
Tariq
Aprilaire 400 not working-dscf0013.jpg   Aprilaire 400 not working-dscf0015.jpg
tariqk is offline   Reply With Quote
Old 12-23-2010, 02:37 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
remove the water lines from the solenoid valve. Incoming side inside the valve is a screen. use a screw to get it out. it may be plugged. on outgoing side of valve is a orifice. It may also be plugged
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
tariqk (12-23-2010)
Old 12-23-2010, 03:41 PM   #3
Thanks, I'll try it and post the results.
-Tariq
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 07:23 AM
Aprilaire humidifier stopped working Richo HVAC 2 11-19-2009 08:28 PM
Is this Aprilaire digital humidistat working right? Studly HVAC 6 03-17-2009 04:29 PM
AprilAire 550 Humidifier not working? mcvane HVAC 2 11-22-2008 12:15 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
