Old 10-18-2009, 07:42 PM   #1
Default Apparently I need a new circuit board?
Hi Guys!
We've got a Goodmans ARUF061-00A-1 A/C furnace, and I'm in a bit of a quandry. We noticed a couple of weeks ago that the furnace fan in our attic was running all the time, whether we set the room thermostat to heat, cool or off! No problems whatever with temperature settings, but we were concerned the the motor running indefinitely would cause something to wear out, even though there is a switch on the thermostat that caters for that.
I got some unfortunatly bad advice that if I connected the white wire directly to the red wire inside the thermostat, and the motor still kept running, then the problem would be the thermostat.
I got a new thermostat, tried to wire it up, got the wires mixed up, messed up both thermostats, and wound up having to pay the an expert we called $200 to fit a new delux thermostat! (They never carry cheap versions of anything in their vehicles do they?) And the original fan problem still prevails.
The technician checked the furnace in our attic, came down, and said that something on the furnace circuit board was burned out, and it would need total replacement to the tune of $433. He said that the resistor (or words to that effect) was to fiddley to try and replace on its own! He he'd said try to get the new C/B in time for monday.
My question is: Do the experts out there feel this is an accurate analysis? Am I paying an arm and a leg for this component (cost includes fitting). Assuming the diagnosis is correct, does it really hurt to have this fan blowing all the time? There is a facility for doing that on the thermostat after all. And finally, should I cancel him and get a second opinion?
Any help on this would be really greatly appreciated.
Pete
PeteUSA44 is offline   Reply With Quote
Old 10-18-2009, 07:54 PM   #2
old pro
There is a fan relay on the board and it probably is stuck on and the board needs replacing. They are nonrepairable. Prices vary from area to area depending on the cost of living so we don't do pricing. Not out of the ballpark for my company. It will cost another $100 or more for a 2nd opinion and it still needs more repairs $$. Running the fan all the time wears it out and costs about 1$/day in my area, do the maths it ain't cheap to run.
Old 10-18-2009, 09:00 PM   #3
Many Thanks yuri
One last thing though, do you think this board is something I could replace myself? I wouldnt mind saving $300 dollars or so if it were possible, since I'm currently without a job?
Pete
Old 10-18-2009, 09:10 PM   #4
An old Tradesmen
Don't take this wrong.
But. You messed on on the stat. look what that cost you. What if you mess up on the board, and wipe out another part beside the expensive new board you were trying to install.
Could end up costing you more then a thousand bucks in parts alone.
Old 10-18-2009, 09:37 PM   #5
old pro
AND, the new board may be a retrofit and require some alterations in wiring. I would get the tech to do it, doesn't sound like he is ripping you off.
Old 10-18-2009, 09:56 PM   #6
Thanks a lot guys for all the advice.
I'll leave it to the experts.
All the best.
Pete
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
If you've had trouble insulating your home from hot summer weather, you might consider investing in an attic fan. While air conditioning can help to cool air in the livable portions of your home, most attics do not have air conditioning. After hours of... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
There is a windshield cover inside the door that protects the cold, hot air coming in This can be peeled away. You locate the power window motor which is behind this panel right here and you trace the wires around and they are here. On this particular... Read More »
Carrier furnace control board - OEM or ICM ? anku HVAC 12 11-06-2009 12:49 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 11:33 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 12:03 PM
installing backer board over particle board bob mac Flooring 5 06-15-2009 07:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 11:41 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
