#16 |
Apollo Forced Air Furnace, leaking water
i know
![]() last i saw anything leaking was during the inspection, and it was a drip. upon moving in i checked in the attic twice and never saw anything, and then (now) two days ago i noticed the PVC drain outside my house was continually dripping, so i went up and checked and thats what i found. i might call someone to come do the job - i hear that hydronic systems are cheaper/easier to work on. i have to work today, and i'm going to assume no one is really available today OR tomorrow, as it's presidents day. -seth |
#17 |
Don't bet on it being less expensive than forced air...
Just slow, not stupid. |
#18 |
well, if my understanding of how this system works is correct, fundamentally, its cake. it's like a radiator with a giant a$$ fan blowing through it, and a pump
#19 |
Then whaere is the boiler portion.
Sounds to me like you have a air handler in the attic.
#20 | |
Electrical Contractor
Apollo Forced Air Furnace, leaking waterQuote:
Turn off the power, remove covers to locate the leak, repair and be done. In the meantime, if it's not super cold, I would valve it off or you're gonna have a nice water and electric/gas bill. |
#21 |
yea i valved it off already
at least the ''hot'' valve. i left the cold one open, so that maybe the cold water could sink back down into the hot water tank (and yes it is setup just as you said) anything else?? could anyone maybe help me find a schematic?? I'd look more but i'm headed out now, the unit is a : apollo H098674361 even a general schematic may help. to fix a leak may require brazing, right? |
#22 |
Soft soldering. Propane and plumbing solder.
#23 |
Yes, you may have to sweat some copper but you may find the leak is at a threaded fitting and hopefully the put some onions
(unions) in there.I wouldn't disable the pump if you have it valved off. Not sure why you would need schematics? |
#24 |
pump was the first thing i shut off. i shut off the whole unit, took power away =p
i dunno, schematic would just be nice so i know what to expect. i'm eating my dinner, then i'm suiting up so i dont get all that insulation dust all over myself ill have my room mate take pics of the epicness :D ill let yall know whats up with pics as well |
#25 |
diagnosis successful! pics and a video coming in about .... 20 minutes :D
#26 |
results:
![]() higher resolution image: http://www.jacqui-of-all-trades.com/...iator_pipe.jpg video: http://www.jacqui-of-all-trades.com/...diator_vid.avi let me know what you guys think my approach should be seth P.S. - this leak is hard to see and small, because I only had the water valve turned on very slightly. If i had the valve turned all the way on, it was spraying too much to take a picture Last edited by sethfc; 02-16-2009 at 07:56 AM. |
#27 |
I have got a similar system "Aqua therm heating system" made by first company.
I just found that there is a 1/4" inch crack on the heating coil (radiator). And this is only about 3 - 4 years old. The property is located in Portland OR. So is it a good idea to swap it with a gas furnace with the AC coil instead of replace the leaking radiator? Thanks, Aaron |
#28 |
An old Tradesmen
Do you have a way to vent the furnace?
#29 |
I think so, since the existing vent for the water heater just goes through the attic to the outside, so I think I could just hook the vent for gas furnace to this vent and it should be ok?
Or maybe I should stick with the existing unit and find some one to replace the heating coil (radiator)? how much does this approach will cost? Thanks, Aaron |
#30 |
An old Tradesmen
Can't vent them through the same flue pipe.
How much it will cost for someone to replace the coil varies with area. Just call a couple places and get prices from them. |
| Display Modes | |
| New Cased Coil - Install to Furnace - PICTURES!! | hartkem | HVAC | 39 | 11-18-2008 02:45 AM |
| newmac wood/oil combo forced air furnace questions | CowboyAndy | HVAC | 2 | 09-22-2008 06:17 PM |
| (Water Heater MYSTERY) Hot water out from dead tank with cold water in it? | Inayity | Plumbing | 6 | 07-14-2008 09:36 PM |
| Ice and Water Shiled over or under Drip Edge? Leaking Roof | sbt3 | Roofing/Siding | 8 | 05-03-2008 12:00 AM |
| Water in Furnace Ducting | sdoca | HVAC | 3 | 09-14-2007 07:54 AM |
