Apartment Heating Malfunction Honeywell Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 05:06 AM   #1
RCH
We have an apartment where the tenant has just moved out. There is a problem with the heating system in that the Honeywell thermostat is not controlling the in line pump in the apartment. There are three apartments fed of one continous loop with the gas fired water heater in the basement. In each apartment the line branches off the main circulating loop. Immediately off the main loop on the branch loop is a pump??? that is controlled by the thermostat....I think. It is a Honeywell Pump and has two 6 amp breakers and a transformer. The previous tenant removed the transformer from the box and placed it externally and seperately but adjacent on the wall. Through some fancy wiring he passes from the mains side of the fuse box through the transformer and appears to bye-pass the breakers straight to the pump.
We changed the thermostat, still doesn't work, all radiators in the apartment on the loop heat up. We have to turn each radiator off to control the temperature.
I am thinking that this it is the pump. The problem is this is an old system and I am not sure of the replacment part. I have a picture but that is about it.
Can someone confirm that my understanding of the system is correct and their thoughts as to what the problem might be?
Thanks for taking the time to consider and respond.
RCH is offline   Reply With Quote
Tags
apartment , honeywell , pump , thermostat , water heater
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 02:26 PM
HELP old apartment .. Return Duct / Heat pump thethrowdown HVAC 1 01-29-2010 03:36 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
heating /water pump broley Plumbing 1 12-30-2005 06:45 PM
