Anyone Try Lindab SPIROsafe? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-10-2008, 08:17 PM   #1
Anyone try Lindab SPIROsafe?
Hello, I have a very confined crawlspace to put ducting in, and I came across Lindab SPIROsafe, which you can get as a double wall R8 insulated round duct that has EPDM gaskets meeting SMACNA Class 3 leakage = no warpping of insulation & no screws & no tape & no mastic, etc.
It isn't cheap, but it sure seems easy. Has anyone tried this product and how did it turn out?
pocketfulladoubles is offline   Reply With Quote
Old 09-11-2008, 10:11 AM   #2
1610 CUB's Avatar
Rewards Points: 150
http://www.lindab.com/USA/web_LINDAB..._submittal.pdf You still need to screw it! Just use single wall pipe and insulate it or use flex thats supported.
1610 CUB is offline   Reply With Quote
Old 09-11-2008, 11:16 AM   #3
Ahhh, thank you, I missed that. That makes it less appealing, but it still may make it easier since there are portions where I can barely fit my body in the crawl space. I just can't imagine wrapping insulation down there.
I was told not to use flex, because of the chance of pests tearing up the flex. Is this normally an issue?
For normal single wall pipe, do I need to seal the joints normally? The Lindab gasketing seems to take care of that issue at least.
Old 09-11-2008, 12:22 PM   #4
1610 CUB's Avatar
Rewards Points: 150
Just how small is your crawl space? #1 mice like insulation, so flex can be a problem, But if you can keep it off the ground it should last a wile. #2 if you use hard pipe tape the joints with foil tape then screw the joint, rap the pipe with 1.5" duct rap and get a small high school kid to install it for $$$
