#1 |
Anyone see a problem with this definition of Normally Open?
Normally Open-
State where current flows until the plunger pin is actuated to close the electrical circuit. Found this definition in an online EPA certification practice test site. Anyone see a problem with it, or is it just me? |
#2 |
NC - Normally Close
NO - Normally Open Original state when doesn't have power voltage applied.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead. |
#3 | |
Thx for your reply JJBoy
What I was getting at: Quote:
#4 |
It isn't clear, but may be the voltage of the coil
#5 |
Average Joe/ex-Navy IC3
When does traffic flow along a city street? When does water flow out along water pipes and out of your faucet or garden house? When does pedestrian flow downtown a busy metropolis along sidewalks?
#6 |
Thx for your reply Greg~, but I have no clue what you're talking about - can't tell if you agree or disagree with my statement "Since when does current flow in an open circuit?"
#7 |
An old Tradesmen
The practical definition of an open circuit. is no flow.
So it should read: State where no current flows until the plunger pin is actuated to close the electrical circuit. |
#8 |
Thank you beenthere.
#9 |
The point that I was trying to prove, is to think about your question that you posted, to figure out the answer about what is Normally Closed, and What is Normally Open.
#10 | |
Anyone see a problem with this definition of Normally Open?Quote:
Sorry for being a bit obtuse and missing your meaning Greg~. |
#11 |
An old Tradesmen
As with going to seminars. The people that write test, often interject their own personal interpretations. And thats what it sounds like the guy did that wrote the test you saw/took.
#12 |
Don't worry. When I went to Basic Electricity & Electronics for the Navy, they had their way of stating things, that was different than how my father taught me about stuff. Then of course, it all changed when you actually got to do the work at your duty station. The process changed along with the way of doing things, but the way things worked in a circuit didn't.
| Display Modes | |
| Open Stairs in Basement | ngerhard | Building & Construction | 4 | 07-10-2009 07:30 PM |
| Stymied by window leakage problem. | Matth3w | General Discussion | 5 | 06-11-2008 07:26 PM |
| garage door open light | deck hand | Electrical | 3 | 01-22-2008 09:29 AM |
| Door -Storm Door problem | bassman | Building & Construction | 2 | 01-17-2007 04:16 PM |
| Post-Tension Slab Problem Advice/Help | Mike McBride | Building & Construction | 2 | 01-09-2007 02:51 PM |
