Old 12-31-2012, 09:36 PM   #1
Anyone Ever install a Williams Monterey Furnace before?
Has anyone installed a Williams "Monterey" Furnace - model 2509622? In the instructions (Figure 14) they show gas piping configurations - however I do not see how any of these arrangements are physically possible with the gas coming in from the stud wall.
In the instructions (Figure 5), the Alternate Gas stub location is 4" above the sill plate.
So, how does this fit in with Figure 14? I need for the shut off valve to be in an unconcealed space, and with the 3" sediment trap, there simply is not enough room underneath the furnace to fit it all! I've been looking online for a photograph of a properly installed wall furnace, and cannot find one.
In (Figure 24) they have a drawing of a Drip Leg (which differs from a sediment trap).
According to the UPC (which I am under), I need to install a sediment trap (like is shown in Figure 14) NOT a drip leg (As is shown in Figure 24).
I could possibly install the heater in the configuration shown in Figure 24... But it would still not be possible to use rigid pipe from the ground joint union to the gas valve because the female portion for the gas valve sticks out into the room a few inches. In other words, it is not a straight line from the hole in the stud to the hole in the gas valve. I think I'm allowed to use flexline, though - so that is why I could possibly do the install in Figure 24... but is it correctly installed if I do it that way?
Any help you can give me with this installation would be great!
fulmar2 is offline   Reply With Quote
Old 12-31-2012, 11:41 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
It is called getting a licensed plumber in that can do the gas piping for you legally, not some hacked together solution.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 12-31-2012, 11:49 PM   #3
Hi Gregory -
Sorry, your reply was not helpful. My permit is "owner builder," and I looked up the rules on "owner builder." As an owner builder, you are legally allowed to work on your own gas piping. My final installation will not be a hacked together solution, but instead a permitted and inspected installation. I came to DIY Chatroom for some help doing that, and to make absolutely certain that I have followed all of the rules before I call the inspector to come out. I assume you do not have any constructive input - but if you do, I'm still open to it!
Thanks!
Old 01-01-2013, 02:52 AM   #4
I've installed numerous Williams wall heaters and many times a drip leg wasn't required especially if the gas supply line rose vertically through the floor. Double check your local code to see what they require. The installation manual I believe uses national codes which may not be accurate or required by local codes.
kirwinjd is offline   Reply With Quote
The Following User Says Thank You to kirwinjd For This Useful Post:
fulmar2 (01-01-2013)
Old 01-01-2013, 03:00 AM   #5
Thanks, kirwinjd.
We're under the UPC, and I did read in Chapter 12 that a "sediment trap" is required - they even have a picture of it that looks like the configurations in Figure 14. I did more research online, and determined that a "drip leg" is not the same as a "sediment trap." I need a "sediment trap." So, now the question is: how to I accomplish that when coming in from the stud wall? I've got 4 vertical inches to work with. Hmmm...
Old 01-01-2013, 11:20 AM   #6
gregzoll's Avatar
I get a owner Builder allowance also when working on my home, but it still does not make me a licensed hvac specialist, or the ability to be a expert in gas piping.
The key is, if you do not know what you are doing, even though you have the instructions in front of you, you call in the experts. As for the location of the drip leg, depends on how the gas piping is run, and if the framing was not put up to take in consideration of that wall heater you are putting in, you will have to make some changes to make it work.
But still take it from someone who knows their limits, call in an expert to do the gas piping. More diyers messing with gas appliances have caused homes to blow up, than experts that do this stuff on a every day basis.
Old 01-01-2013, 12:53 PM   #7
Those instructions you are reading would mean absolutely nothing where I am from...... must follow the B.149..
carmon is offline   Reply With Quote
Old 01-04-2013, 02:18 PM   #8
Hi Carmon - Well, I've read the UPC too. I see what I need to do according to the UPC - so perhaps I should just ignore the part in the instructions that says to set the feet of the furnace on the sill plate. I went over and looked at an installed one (same county), and they raised it up a few inches higher than my instructions say to. This would fix the issue of the sediment trap not fitting (interestingly, the installed one I looked at did not have a sediment trap or drip leg - but it was put in several years ago).
Old 01-04-2013, 10:41 PM   #9
For what it's worth, I've repaired countless Williams wall heaters and I've yet to see one that had a drip leg or sediment trap. I'm not suggesting that these were all installed properly or improperly. But because of the tight working space, it seems that the building inspectors in my area over look that requirement.
fulmar2 (01-04-2013)
Old 01-04-2013, 11:16 PM   #10
Kirwin - Thanks for your helpful comment. That is good information to have. I think I'm going to just move the heater up a few inches to accomodate the sediment trap. The manual says a minimum ceiling clearance of 16", which is easily attainable. It frustrates me that the diagrams they show in the manual are physically impossible to assemble. I think that I have the best chance of pleasing my inspector if I add the sediment trap. Thanks again!
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 11 12-16-2012 07:18 AM
Install Help on 75K BTU Garage NG Furnace live4spd HVAC 23 10-15-2011 08:58 AM
air cycler install for bryant 90 gas furnace bill c Electrical 1 10-29-2010 10:53 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 10:31 AM
