Old 06-24-2009, 01:54 PM   #1
Is anybody still currently installing 13 and 14 seer systems
I have been reading that one can have a 19i installed for the same price as a 14i because of current high efficiency unit incentives (tax credit, Trane rebates, poco rebates, etc.). I was wondering if a lot of people are not taking advantage of these incentives and why not. One of the main reasons I ask is that my brother wants me to replace his unit. The only problem is that I will more than likely not be able to get him the tax credits and rebates. I recently changed career paths, but I do still have connections in the HVAC field. I can still get the equipment from my old company. Also, my state allows a home owner to pull a mechanical permit for the job. I will likely only charge $1500 over the equipment cost. This will cover slab, drain pan, duct board, disconnects, my time, etc.
pomelo is offline   Reply With Quote
Old 06-24-2009, 02:42 PM   #2
30 year tech
hvac122's Avatar
We install them all the time. Still cheaper even with the credits.
hvac122 is offline   Reply With Quote
Old 06-24-2009, 02:44 PM   #3
sktn77a's Avatar
Well, you may not be able to get the manufacturer's rebate (as they typically split them with the installing company), but there's no reason he couldn't get the federal tax credit or utility rebate.
sktn77a is offline   Reply With Quote
Old 06-24-2009, 03:01 PM   #4
The utility credit is pretty small in my area, and you have to be a contracting partner. I'm not sure how the tax credit works, but I would assume he would need an invoice of some type. I know prices are highly localized, but I believe a 19i can be installed for around $6k to 7k after incentives. A 13 seer would run him about 4k if I installed it.
One last question, does a 15i with a matched variable speed air handler qualify for any of these incentives?
Old 06-24-2009, 04:22 PM   #5
HVAC / Plumbing
The manufacture of the equip. should have a list of which units qualify for the tax credit
kenmac is offline   Reply With Quote
Old 06-24-2009, 06:32 PM   #6
An old Tradesmen
So who is going to cover the 2 year labor warranty that 19i is suppose to come with?
Old 06-24-2009, 08:34 PM   #7
GC/Master Plumber/Mech
Same here
Old 06-24-2009, 08:38 PM   #8
An old Tradesmen
Yep.
13 and 14 SEER are cheaper cor the customr then a 18 or higher SEER.
Old 06-24-2009, 08:51 PM   #9
Home Air Direct's Avatar
13 & 14 SEER account for over 90% of the current retrofit market.
As said above, this equipment is still the best buy, even without the tax credit. If you take the $1,500 tax credit and balance it against the additional costs associated with the qualifying equipment, it actually takes a lot longer than you realize to gain back the difference gained by efficiency over a tried and true workhorse well built 13 or 14 SEER system.
And, the higher efficiency equipment and air delivery systems are not always well suited for older, loose homes, and this adds even more time to the recoup timing that never shows up in a cost/benefit calculation.
If your situation is one that you have a well designed home that can take full advantage of higher efficiency air delivery systems, and you must have the best (for whatever reason), than go for it, but don't get so caught up in the tax credit for the sake of getting the tax credit.
Being a country boy, we call this "Swallowing elephants and then chocking on ants".
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-24-2009, 08:53 PM   #10
Originally Posted by beenthere View Post
Yep.
Beenthere just said in one sentence what I said. He wins
Old 06-24-2009, 10:41 PM   #11
I'll cover the warranty. I have been repairing his units for quite a while. I'm pretty close to my old boss, so he usually gets me the parts. Does anyone have a link to a calculator for cost analysis? I want to try to estimate the payback period and cost savings of higher efficiency units.
Old 06-24-2009, 11:15 PM   #12
Here ya go.
http://www.acdoctor.com/cooling_calculator.php
Whole House Water Treatment Systems HWPipes Plumbing 21 04-25-2013 09:53 PM
Comparison of subfloor waterproofing systems formarley Building & Construction 5 10-22-2009 11:03 AM
Ductless mini-split A/C systems bayouelton HVAC 3 08-02-2008 09:15 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Compairing PEX Manufactures and Systems recumbent615 Plumbing 2 04-02-2008 06:18 PM
