Any Reason Why Not? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 02:02 PM   #1
the Musigician
DangerMouse's Avatar
Any reason why not?
I'm wondering if there is any reason why I shouldn't turn off the furnace's breaker until next winter? There are at least two little lights running and regardless how small, they still use power!
Thanks!
DM
Old 05-23-2011, 02:17 PM   #2
Learning by Doing
Leah Frances's Avatar
I am often reluctant to shut things like this down for fear they won't start when you go to switch it back on.....
The two LEDs on my boiler may cost a MINUSCULE amount of power during non-heating months. But they serve the purpose to re-assure me all is well.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-23-2011, 02:26 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Turning the breaker to the furnace off means no air whatsoever so if you don't need it, not a problem to turn it off.
Doc Holliday is offline   Reply With Quote
Old 05-23-2011, 03:17 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 92
I agree with Leah. When I shut off the power to one of my computers the power supply cooled down, contracted and died. Computer service guy said that is not uncommon. Now I leave the power on all the time. The transformer runs warm in your furnace and cooling it down in theory may contract it, loosen the plates/windings and then it can buzz. 1 watt LED costs 1/1000 of a kw to run and you probably pay under $10c/kwh so it ain't worth it.
Old 05-23-2011, 03:19 PM   #5
the Musigician
It's only for heat in winter, no A/C to it at all.
My "home-made cooling system" covers that for the most part, we rarely ever need to turn on a window unit.
So I can turn it off no problem?
DM
Old 05-23-2011, 03:20 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 92
Yep...
Old 05-23-2011, 04:36 PM   #7
Rewards Points: 252
I turn off my upstairs unit during the winter when my kids aren't here. Enough heat migrates that way from downstairs and it doesn't kick on. I hate hearing the upstairs heat pump turn on when nobody is up there. I would do it.
Marty1Mc is offline   Reply With Quote
Old 05-23-2011, 05:19 PM   #8
An old Tradesmen
Rewards Points: 7,768
I'll bet those lights cost 2 cents a month.
Old 05-23-2011, 05:23 PM   #9
the Musigician
2 cents a MONTH???? We can't afford THAT!
Now I GOTTA turn it off!!!
DM
Old 05-23-2011, 05:38 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 92
Prevents global warming. No need to burn coal to produce the power for those LEDs. Gotta get me one of these to save my dollaros and burn off some carbs.
Old 05-23-2011, 06:01 PM   #11
biggles's Avatar
pick up a spare transformer and leave it inside the unit when you repower it in the falll chances are it might pop the winding on the primary or even that secondary
Old 05-23-2011, 06:46 PM   #12
Rewards Points: 968
lol you guys crack me up
federer is offline   Reply With Quote
Old 05-24-2011, 08:20 AM   #13
Learning by Doing
I fear Murphy's Law. I also think that any additional or unpredictable action can result in collateral damage.
How many times have you replaced a part or fixed something only to have something different and unrelated fail when you go to start it up?
For example: we took my huband's M3 in for an alignment yesterday. We took it to an excellent shop where we trust the people there completely (anyone want a recommendation for a speed shop primarily Subaru... PM me).
When we left the shop the convertible top no longer works. While I am certain they neither a) messed around with the top and b) are trying to generate more problems (because they don't have the knowhow to fix it); I can't help shake the feeling that the two actions are related.
Missing roof rafter (any reason?) Joe1. Building & Construction 2 09-11-2010 10:01 PM
Any reason why to NOT use a GFCI somewhere? Red Squirrel Electrical 7 01-15-2010 01:16 PM
Chipped & Full round head nails, whats the reason ? iMisspell General DIY Discussions 4 12-14-2008 01:30 PM
smoke detectors going off for no reason? arichard21 Electrical 18 04-20-2008 10:37 PM
Any reason I shouldn't add to this circuit? Mdbuilder Electrical 11 12-07-2007 07:00 PM
