Any One - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 02:00 PM   #1
any one
any one have any ideas on a ducan furnace not working?
kevin s brink is offline   Reply With Quote
Old 02-22-2009, 02:17 PM   #2
HvacWiz's Avatar
Rewards Points: 252
A little more info would be a good place to start.
HvacWiz is offline   Reply With Quote
Old 02-22-2009, 02:21 PM   #3
i have a ducan furnace 90%. i had some problems with it lighting up. i cleaned it out and replaced the air filter, turned it off for 5 min and went to restart it and it would flash a 4 code went through and removed the panels did some cleaning and retried and it started working. this was the this am, been fine since. any knowns on what causes this.
Old 02-23-2009, 05:26 AM   #4
probably overheated when you removed the panels especially if it was in the middle of a heating cycle removing the doors and putting them back on reset the circuit board... no worries
kennzz05 is offline   Reply With Quote
Old 02-23-2009, 05:19 PM   #5
the panels were removed for cleaning only the problem was before i cleaned the unit out. when trying to restart the furnace the panels were all on and reassembled properly. then when i turned off all power to unit and waited for awhile and turned on power to unit that is when it started working properly. just more info.
Old 02-23-2009, 06:35 PM   #6
You need to be way more specific about how it's acting. You know, like does it make any noises. Does the inducer motor run? Does it try to light the burners?
By the way what are you using for heat since the furnace went down yesterday at 1 PM.
hvaclover is offline   Reply With Quote
Old 02-28-2009, 08:53 AM   #7
the only thing on or running is the main blower motor not the induction blower and was not trying to ignite . mean while it was flashing a code 4.
Old 02-28-2009, 10:24 AM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 136
Find the code sticker on the back of one of the panels or the owners manual and tell us what it is. How old is the furnace? Post the model and serial#.
Old 02-28-2009, 11:51 AM   #9
What have you been using for heat all week?
Old 02-28-2009, 12:20 PM   #10
