Any Dealer/installer Recommendations In Cincinnati? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2005, 12:19 PM   #1
Any dealer/installer recommendations in Cincinnati?
Possibly looking to replace my a/c unit since we have to have someone service it about every 1.5 years to charge it. It's probably about 10 years old, and I'm trying to be pro-active before it really goes. Another factor is the new regulation going into effect sometime in January '06, that will prohibit the sale of a/c units with less than a 13 SEER rating. I'm not sure exactly what that means, but I do know it means a considerable difference in price between a unit with a 13 SEER and one less than 13. Figured if I look into replacing it now, I might save some money....if dealers in town still have units in stock with less than 13 SEER. Another factor I think will effect pricing is whether to go with a unit that utilizes Puron, which is in Carrier units, but might be called something else in other brands, or going with the R22 refrigerant.
Recommendations? Thoughts?
Thanks.
daveincincy is offline   Reply With Quote
Old 12-29-2005, 01:18 AM   #2
SEER means " seasonal energy efficiency rating ". Basically in the case of the 13 SEER unit you can remove 13 btu's of heat for every 1 watt of electricity consumed. This is under perfect conditions, which cannot be duplicated once it leaves the factory . You can also create problems by mis-matching units, like changing only your outdoor portion of your unit to a higher SEER and not the inside unit. This is speaking of a split system.
oddjob is offline   Reply With Quote
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 11:09 PM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 10:12 AM
book recommendations mnp13 Electrical 2 05-02-2007 12:37 PM
Respirator recommendations? carrie brooklyn General DIY Discussions 2 06-04-2006 10:54 PM
Anyone have an installer recommendation in Cincinnati? daveincincy Remodeling 5 01-02-2006 09:08 PM
