Old 10-16-2009, 11:05 PM   #1
Default Antifreeze in a boiler ?
I have a old Burham boiler furnace, it has car antifreeze in the system, is this okay?
american501 is offline   Reply With Quote
Old 10-16-2009, 11:11 PM   #2
Master Plumber/Mechanical
Anti-freeze is ok
The anti-freeze will have anti-corrosion additives that can help the piping from failing
However I would every year or two take a sample and have the ph tested to make sure you have a balanced water
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about diagnosing coolant leaks. You may first notice a coolant problem because your car is over heating or running a lot harder than it should. The first thing you want to... Read More »
About Engine Coolant Leaks
About Engine Coolant Leaks by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about common coolant leak points. There are several common coolant leak points. First you want to check the coolant overflow reservoir for cracks or leaks around the hose... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question how do I fix a coolant leak. There are a lot of products that you can add to the coolant which will help seal small leaks in your coolant system. However if... Read More »
Hello! This is Jon on behalf of Expert Village. In this video clip, I will be talking about how to check your coolant level. The first step in checking your coolant level is to pop the hood and locate your coolant reservoir. Usually it is located along... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will show you how to check for engine coolant leaks. As you take a look at your engine coolant reservoir, you will notice that there are several hoses coming and going from your... Read More »
pilot light on crown aruba boiler mazzonetv Plumbing 1 05-28-2009 12:13 PM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 07:27 PM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 10:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 06:21 PM
Circulation pump on boiler uncleneiler Plumbing 2 05-09-2008 11:59 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
