Old 10-29-2012, 12:25 PM   #1
how
Another debris plugged gas valve.
Just ran across a gas valve plugged with small, slightly rounded slivers of debris. They were pretty uniform in size and were mainly bunched up at the screened inlet. The preceding line was copper and had a drip leg that was 6 feet from the furnace,. The slightly rounded shape of the debris matches the curvature of the copper pipe so I am assuming the debris is from the 6 feet of copper pipe.
I have seen this twice before on one other furnace , where the plugging was 7 years apart.
Anyone have any ideas or experience on how this could happen?
how is offline   Reply With Quote
Old 10-29-2012, 12:37 PM   #2
For some time copper was being discouraged because of gas containing a significant amount of hydrogen sulfide . Some areas of distribution were worse than others . While it is discouraged for use with NG but is approved for LP I've seen black flakes in propane copper lines that will plug a screen .
Fairview is offline   Reply With Quote
Old 10-29-2012, 02:05 PM   #3
JJboy's Avatar
In Texas, it's code now to install a trap on the gas line.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 6 03-21-2012 02:26 PM
re-soldering a valve joint rtoni Plumbing 9 11-05-2010 11:04 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
