Another Comfortmaker Furnace Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 09:26 AM   #1
Another Comfortmaker furnace won't turn on
I also have a Comfortmaker GUH series from the early 90's. It has intermittently locked out leaving the blower running this season. At first it was very intermittent. Now more so. I have a single flash of the indicator and after the prescribed 60 seconds of updraft observe the igniter region getting bright orange. After a no light situation it repeats with a longer igniter period. But still no go.
While checking things out I achieved ignition/flame after jostling the small gas tube that is situated near the bottom of the middle tube. I checked the manuals and nothing indicates where it should be positioned. So the first question is to understand where it should be.
The second question relates to cleaning. I have seen in many places where cleaning is encouraged as a solution. Can anyone describe that in better detail. I am an engineer and quite mechanically inclined but am not knowledgeable about furnaces, per se.
Thanks - also open to any other suggestions.
Oops - I just saw the comment above. Should I make a new thread even though th etopic is the same???
Ron
Ron From MI is offline   Reply With Quote
Old 12-03-2011, 11:31 AM   #2
An old Tradesmen
Rewards Points: 7,332
made this its own thread.
Old 12-03-2011, 11:39 AM   #3
HVAC Tech/ Browns Fan
Look like you need a service tech. Because need to see if gas valve is opening and he will that the right tools for it
Tator1076 is offline   Reply With Quote
Old 12-03-2011, 12:00 PM   #4
Can I observe any voltage condition for the gas valve to know if it is being requested to turn on? There are 2 pink wires leading to the gas valve (positions 1 & 2) and a jumper between positions 1 and 3.
I agree if it is gas valve related that a service tech is required. That is one area I have avoided playing with in the past.
Old 12-03-2011, 12:06 PM   #5
biggles's Avatar
check this video might give you a direction or seach youtube with you problem for a techs suggestions
Old 12-03-2011, 12:44 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
post some pics of it with both doors off and a closeup of the igniter area. there are lots of different versions of that furnace. then we can narrow down the problem.
Old 12-03-2011, 01:09 PM   #7
Here are a few pictures. It is a 1992+ Comfortmaker 90+ efficiency 100k BTU GUH100
Old 12-03-2011, 01:18 PM   #8
And one more of the igniter. Much of it is covered but here it is.
Old 12-03-2011, 01:35 PM   #9
Hvac Pro
yuri's Avatar
don't have any of those where I am but it looks like that small line is a vent line for the gas valve diaphram. very common years ago. in order to open the diaphram needs to vent gas from underneath itself. try unscrew it completely (temporarily) to see if it will open. if the end of that line is clogged/burnt closed the valve won't open properly. not sure where it should be positioned but it is a VERY small amount of gas that comes out of it so anywhere near the burners w/o it getting melted is OK.
Old 12-03-2011, 01:48 PM   #10
how
Rewards Points: 1,104
OK I'm confused.
The pictures seem to show a gas valve with a skinny aluminum pilot tube going into the exchanger. Is this solely for a crossover feed? because I don't see anything to verify a pilot flame, just the main burners.
I've just seen Yuris post about a diaphram gas valve bleed (which is what it looks like) but I have not seen such a gas valve in anything younger than 78. Maybe "Ron" can show or tell us where this tube terminates?
I was going to say to "Ron from MI" that the next step would be to see if the two pink lines to the gas valve are getting 24V during or after the igniter starts to glow. This would point toward whether the problem in the gas valve or the board.
how is offline   Reply With Quote
Old 12-03-2011, 01:53 PM   #11
Hvac Pro
yuri's Avatar
pic #1 yellow wire goes to the flame sensor I believe. I have seen that yellow wire on other ICPs and if it has a HSI then it has a flame sensor. The round job on the far right burner is one of those old round HSIs that look like a candle. Therefore the flame sensor would be on the farthest left burner where that yellow wire is IMO.
Old 12-03-2011, 02:48 PM   #12
I tried checking power to the valve and could not. I wondered what is the appropriate common/ground for it.
I did remove the flame sensor and cleaned it. Yes it has the small yellow wire.
The small line from the valve terminates near the center burner tube. I will try it with it disconnected to verify it is not stopping anything.
Ron
Old 12-03-2011, 03:00 PM   #13
Hvac Pro
yuri's Avatar
you can put your meter on AC volts across those 2 pink wires at the gas valve. should get 24 volts when it energizes. don't worry about the jumper.
Old 12-03-2011, 03:07 PM   #14
Thanks I will give that a try
Old 12-03-2011, 03:18 PM   #15
how
A diaphram bleed line should be able to just be unscrewed from the gas valve and blown through. The are usually clamped near a source of flame but if you are able to blow through it you can leave the clamped end in place. If you can't blow through it then the obstruction is usually right at its end near the flame. A paper clip will clear out the debris and if not, removing the last inch of tubing will usually deal with it.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Comfortmaker furnace won't fire Scott Little HVAC 26 09-23-2010 07:38 PM
comfortmaker furnace; i've done the hard part by taking the blower motor out Hurell HVAC 2 06-05-2010 01:03 PM
Comfortmaker furnace problem Big Red HVAC 11 02-10-2008 05:56 PM
