Another Blower Motor ?, Install Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 05:55 PM   #1
Another Blower Motor ?, Install help needed
Im stumped. Can't find anything about this capacitor (AMRAD 15.0 MFD Rheem p/n 43-21298) and the two brown wires that go to the capacitor from the BM. These are two exact colored wires. What's the dif?
Im replacing the Blower Motor that burned out a few days ago, same time I was trying to figure out a problem with another Blower Motor. See my other other thread.
Am changing BM in a Rheem Criterion II. BM is an Emerson Model ZK55HXXDP-7023, replacing w/ Emerson Model # 51-2503-01. These two brown wires coming out of the motor does it matter how these wires are connected to the capacitor? Its the only placed Iam stumped, (so far)!!
Blower Motor expected to arrive tomorrow so will get better handle on this. Btw, I bought a new capacitor 15 MFD 370v 43-25136-08 per suggestion found on this forum. THx to unknown person who recommended! Always best to replace old capacitor with new when replacing the old BM is what I've read. Its been a very hot week in Oklahoma!
HVACMac is offline   Reply With Quote
Old 08-18-2011, 06:13 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Am changing BM in a Rheem Criterion II. BM is an Emerson Model ZK55HXXDP-7023, replacing w/ Emerson Model # 51-2503-01. These two brown wires coming out of the motor does it matter how these wires are connected to the capacitor?Do you know Max?? Max no difference Its the only placed Iam stumped, (so far)!!
Hope you have LOTS of patience when changing that motor. There are more blasted screws to remove than Carter has Little Liver Pills
http://www.google.ca/url?url=http://...5VK-_Q&cad=rja
Old 08-18-2011, 06:20 PM   #3
biggles's Avatar
doesn't matter......
Old 08-18-2011, 07:06 PM   #4
Thx, my hunches said no matter.
Let me check my fire insurance plan first before I proceed! thx.....Ron
Old 08-19-2011, 09:37 AM   #5
Screws? What screws......
Old 08-21-2011, 10:28 AM   #6
UPDATE:
Replaced Blower Motor, All looks and feels great! Although, motor has "different" hum louder than usual as compared to previous BM. I guess I'll have to live with it. Anyway, anyone know what kind of money this would have cost me? Iam in the Tulsa area. Blower Motor and Capacitor + shipping cost me $168.00. The process was actually quite simple. My unfamiliarity is what took far too much time. I swear I looked at my pics I took of the wiring at least 10 times to make sure it went exactly to the spot. Btw, Thank you for the input!
Old 08-21-2011, 12:31 PM   #7
An old Tradesmen
Rewards Points: 8,236
Are you sure the new motor uses the same size capactor as the old motor did.
Old 08-21-2011, 01:05 PM   #8
According to Comfortguru website it does. Motor is virtual exact replacement as recommended by CG.
Old 08-21-2011, 02:30 PM   #9
AKA HVACTECHFW
Rewards Points: 1,208
Verify what the capacitor value should be on the motor box or on the motor label. New motors should not hum!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-21-2011, 05:05 PM   #10
Its not a loud hum, but it does hum.
Ok, below are pics of new Blower Label and these are specs for the new capacitor.
Type: Single Round (Continuous)
Capacitance (uF): 15
Voltage (VAC): 370
Dimension A (in.): 1.890
Dimension B (in.): 1.770
Dimension C (in.): 2.380
Connections: 1/4 in. Quick Connects
It seems okay. Your thoughts?
Old 08-21-2011, 05:20 PM   #11
AKA HVACTECHFW
looks like it is the correct one for the new motor, but I would be leery as to why it is humming, not matter how loud.
IT IS WHAT IT IS
Old 08-21-2011, 05:28 PM   #12
Its at a certain pitch that I find irritating. Now, get this, I replaced the old motor because it too had an awful hum and worsening as time went on, far worse than what I am hearing now. The old motor was very hot to the touch, had a, hot oily burning smell. Travels all through-out the house. No smells now. That's one good thing plus we're all so cool after a week of no a/c.
Old 08-21-2011, 06:10 PM   #13
An old Tradesmen
I don't think your new motor is the right motor.
Looks like old motor was 1/5, 1/8, 1/10 HP, and the new one is a 3/4 HP, way too large. Will end up having a short life span.
Look at the amp draw difference, old motor highest is at 1/5 HP and its 6.5 amps, new motor is 9.5 amps.
Old 08-21-2011, 10:54 PM   #14
Whoops, got the upstairs BM mixed. I'll change pic in the AM. Good catch!::
Old 08-22-2011, 02:36 PM   #15
Photo corrected! Had pic of another motor....sorry about that....
Furnace Blower Problem, help needed!!! lddnyp HVAC 4 01-15-2013 01:02 PM
Blower Motor Wiring reversed? HVACMac HVAC 60 08-30-2011 02:10 PM
Blower motor shorting out lewispm HVAC 1 06-18-2011 10:56 AM
Water heater blower needs re-wire kittf Plumbing 7 12-18-2010 10:44 PM
