Analog Thermostat To Digital Thermostat Conversion Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 01:27 PM   #1
Analog thermostat to digital thermostat conversion problem
I am replacing my old GMC analog thermostat for a Honeywell TH6220D (I have a heat pump). After replacing it my heater is blowing cool air. I called Honeywell and they informed me that I purchased a contractor model and can not help me. Here is how my old thermostat was wired:
Y=>yellow
G=>green
R=>red
O=>orange
W2=>white
E=>brown
C=>blue
I installed the new thermostat and wired the same color/letter, after 20 minutes I still had cool air blowing and inside temp went down 2 degrees.
Any help would be greatly appreciated. Thanks!
godcomplex is offline   Reply With Quote
Old 01-13-2010, 02:42 PM   #2
An old Tradesmen
Rewards Points: 6,140
help to know what brand heat pump you had.
Old 01-13-2010, 02:52 PM   #3
Sorry, I believe it's a Goodman and the old thermostat was a Janitrol hpt18-60. Thanks.
Old 01-13-2010, 03:19 PM   #4
An old Tradesmen
In installer set up.
Do you have option 1 set to 5
And option 2 set to 0
Old 01-13-2010, 03:29 PM   #5
I did have those settings eventually and everything seemed ok, but auxiliary kept coming on during the "heat on". I didn't think that was suppose to happen.
Old 01-13-2010, 03:33 PM   #6
An old Tradesmen
Depends how cold it is outside, what temp you have it set for. And if you raised the set temp by 2 or more degrees.
Aux heat comes on when ever the heat pump can't handle the load.
Old 01-13-2010, 03:38 PM   #7
Initially I set it 73 degrees (8 degrees higher than room temp) Aux came on. I raised it 2 degrees 15 minutes later and aux came back on. Is it possible that this has always been the case and I never was aware because of the old thermostat?
Old 01-13-2010, 03:47 PM   #8
An old Tradesmen
Yeah. The old stat may not have had a light to indicate the aux was on.
And the aux should have come on. In the description you gave above.
Its operating normally.
Old 01-13-2010, 03:50 PM   #9
Thank you...beenthere you are a life saver! I appreciate the super fast help!
Ford Ranger Thermostat Problem? suzikg Automotive Repairs 21 04-18-2014 11:54 AM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 10:22 AM
