American Standard Ignitor - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2007, 07:05 PM   #1
Rewards Points: 85
I replaced my igniter last February (2007) and after no heat yesterday again replaced the igniter. The unit is a newer American Standard furnace. Is it common for the igniter to need replacing once a year?
Thanks in advance for your reply, rredpgg
rredogg is offline   Reply With Quote
Old 11-28-2007, 07:10 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi rredogg
It is very uncommon for an ignitor to fail anually. It is more likely do to shipping damage or inproper installation procedure. If you touch the silicone carbide portion of the ignitor the oil from your fingers will seep into the poors of the ignitor and cause hot spots. If you bump the silcone carbide portion against anything while intalling it, it will put micro fractures in it. As soon as the ignitor warms up it is already failing. Hope this helps with your question.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 11-28-2007, 07:40 PM   #3
Rewards Points: 85
Originally Posted by #CARRIERMAN View Post
Hi rredogg
Good luck
Rusty
Rusty,
Thanks for the reply. As it turns out the last time around my son replaced the igniter and knowing how he works he had his mugs all over it. This time it did use latex gloves while handling the igniter. Time will tell I guess.
Thanks again, rredogg
Old 11-28-2007, 07:42 PM   #4
Rewards Points: 85
Rusty,
Thanks for the reply. As it turns out the last time around my son replaced the igniter and knowing how he works he had his mugs all over it. This time I did use latex gloves while handling the igniter. Time will tell I guess.
Rheem vs American Standard Vicki HVAC 23 10-16-2010 02:44 AM
Questions about American Standard Products bhpizza HVAC 5 06-12-2007 08:36 PM
American Standard or Carrier? lilvree HVAC 1 02-09-2006 07:57 AM
American Standard or Trane lilvree HVAC 1 02-06-2006 11:22 PM
American Standard vs. any other brand can'tdecide Plumbing 2 10-05-2004 06:54 AM
