-   -   American standard heat pump question. (http://www.diychatroom.com/f17/american-standard-heat-pump-question-128704/)
SS laser 01-03-2012 08:30 PM
Hello Everyone,
I have a heat pump problem. The heat pump will not kick on the 2nd set of heat strips. I think it just a bad ODT. The ODT is part number: TAYSTAT250A
Things I have checked. I turned up the ODT to a higher temp 40 degrees. Was at 35'ish as best I could read. Turned on the emergency heat to make sure both sets of heat banks kicked on.
Now I would like to test the ODT with a muiltimeter. What should it read? :whistling2: Not sure how it will read compared to other "switches". I would guess with the outdoor temp colder then it is set for it should be open? So if closed it is bad?
Also can anyone recommend a different INDOOR thermostat for me. I hate the American Standard ACONT401AN21MA.
I have a American Standard TWE037E13FB1 air handler variable speed with 19KW heat strips (BAYHTR1419BRKAC).
I would like to run it in 2 or 3 stages with or without a outdoor stat. 1st stage just be the HP for the 50 degree days. 2 stage would be the heat pump with 1 set of heat strips. And of course 3rd stage is both heat strips and heat pump.
I am looking into the honeywell FocusPro 5000. Waiting for a email from them.
Thanks for any help.
hvactech126 01-03-2012 10:04 PM
A vision PRO IAQ would be what you want. A 5000 series will not provide enough stages.
SS laser 01-03-2012 11:09 PM
I don't want to much of a stat. Maybe just do 2 stages like I have now. Then I think the 5000 will work. Any help on the ODT problem?
hvactech126 01-04-2012 05:10 AM
By the time you buy a new ODT you might as well get a stat that does everything you want and delete the old analog ODT. Just my opinion.
A TH8320 would do what you want just only give you 2 stages instead of three and you can still add a ODT to give better control over the operation.
ON to your ODT problem. When you set the stat to E heat did both banks run? How is your current ODT wired in. I can't tell you what it should read with a volt meter unless I know how it is wired in as those were a field installed add-on. Some installers put them in with different wiring methods.
SS laser 01-04-2012 09:26 PM
When on emergency heat both banks run. I think the ODT is hooked to the X2/W2 and W1. I will look again. There are a few wires in there. I know in the furance there are 2 white on W1 and 2 black on W2. I will check it again and write it down this time.
I will see if I can find that stat. Also found a aftermarket white rogers or goodman ODT for 40'ish online. Will any ODT work? Or does it have to be american standard or trane?
Thanks for your help.
hvactech126 01-04-2012 09:35 PM
any stat should work. as long as they have normally open contacts that close on fall
