American Standard Furnace/ No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 10:24 AM   #1
I have an American Standard Model#cdb100a945d3. Overnight it quit coming on. I have chked the code on the control bd and it is giving just 1 slow flash which indicates normal operation with no call for heat. The temp in the house is 64 and I have the thermostat set on 72. I have turned the t-stat all the way up & still & turned the unit on and off and still no response. The thermostat is a Climate Technology digital thermostat. Is this a problem with the thermostat or where should I start looking?? Thanks
ouhogfan is offline   Reply With Quote
Old 03-09-2012, 11:17 AM   #2
how
Rewards Points: 1,104
Make sure the thermostat has not been switched to something other than a heat mode or that you have dead batterys.
To test the thermostat, turn off power, pull off the thermostat sub cover and jumper or connect together (R & W). Turn power back on.
If furnace comes on ...Faulty or miss set thermostat.
You can also do the same thing where the thermostat wires connected to the furnace board to check both the thermostat & the wiring circuit.
Turn off power, remove stat lines R & W, put jumper from board connection R to W. turn power back on. If the furnace runs it will be a faulty thermostat, stat wiring or their connections.
how is offline   Reply With Quote
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
American Standard Freedom 80 Furnace Jepierson HVAC 1 07-06-2011 05:22 PM
American Standard Freedom 90-No Heat pbrjtr1 HVAC 2 02-04-2011 10:28 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
