Old 01-29-2010, 04:25 PM   #31
American Standard Furnace Mystery
I pulled off the inducer housing again and took a look at that gasket again. It turns out that it wasn't caulk that came off. The rubber on the gasket itself appears to have melted. The entire outside/back of it melted off. The front face that sits directly against the face of the inducer has two or three cracks in it as well. I only found the part online in one spot only. 21D340234 P01 http://bestbuyheatingandaircondition...tegory_Code=CP It is apparently obsolete, but I can't find the newer part. Any ideas?
I think I found the bulletin that was sent out for this very issue. Those parts pictured are identical to the ones in mine only flipped since mine was converted to downflow.
http://docs.google.com/viewer?a=v&q=...Wx9tfwBVgmMLvg
David6 is offline   Reply With Quote
Old 01-29-2010, 09:42 PM   #32
JohnH1's Avatar
That bulletin does not describe your problem. Eather you are drawing to much negitave psi overcomming the hight of the trap. or mabye the trap is not trapping the water.
Look into the trap to see the wall in the trap still in place inside the trap assembly. Without a trap you will suck air up the drain tube and not allow condensate out of the furnace untill the suction stops (IE: induser stops) this is what it looks like. I have never seen a trap fall apart but anything can happen.
John
JohnH1 is offline   Reply With Quote
Old 01-29-2010, 10:10 PM   #33
Hvac Pro
It could happen as they are only held together with a thin layer of silicone or it was built on a Friday afternoon or Monday morning.
John, I am surprised that trap is not vented with a 1/4" hose like the Ducanes/AirFlos and Carrier and ICP traps. Poor design IMO.
Back to the Deep Freeze here, will try send some of it South, LOL
Old 01-29-2010, 11:27 PM   #34
JohnH1's Avatar
I will take the cold it is good for biz. I could always use more work.
Old 01-30-2010, 05:47 AM   #35
I found a forum on another site where the pictures are exactly what mine looks like.
Last edited by beenthere; 01-30-2010 at 05:51 AM. Reason: Removed link to a competing forum
Old 01-30-2010, 05:52 AM   #36
An old Tradesmen
Please don't post links to a competing forum.
Maybe you want to down load the pic. And then upload the pic to here.
Old 01-30-2010, 09:36 AM   #37
Sorry, thank you for the correction. I should have thought before doing that.
Upon reading the bulletin a few more times, John is right. Luckily, I don't see any signs of a cracked collector box. I'm keeping my fingers crossed. I think my problem is just the transition. I've tried to track it down online (#RCT00084), but I'm having no luck. The Trane parts store near me is closed this weekend. Any idea how much I'm in for? I just want to be prepared for sticker shock. Thanks all, I think I'm close.
Old 01-30-2010, 10:50 AM   #38
An old Tradesmen
No, I have no idea.
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-09-2011 12:33 AM
American Standard 5000 gas furnace PyrateJim HVAC 20 01-05-2011 02:48 AM
American Standard Freedom 80 Furnace not igniting all 4 burners chetw66 HVAC 2 09-25-2009 06:01 PM
American Standard or Comfortmaker Furnace jmff HVAC 16 05-03-2009 10:05 AM
