#1 |
American Standard furnace blower second stage goes off during heat call,6 LED flashes
American Standard Freedom 90 gas with electromate coil with a warm flo controller
Initial problem was blower would not come on at all so I put in a new ECM and the blower seemed to work as it should but now it seems after a heat call is on for an extended period of time the fast blower stage will shut off and the blower will just run slowly even though the heat call is still on. The electric coil is still on even with the slow blower. In this state the red LED flashes 6 times which is "115 volt AC power reversed, poor grounding or system voltage too low." If I cycle AC to the unit it will run as it should with the fast blower on a heat call for as long as I have waited (about 15 minutes). Any ideas? |
#2 |
An old Tradesmen
Any electrical work done in the house recently, say the last six weeks or so?
#3 |
I recently replaced the main switch on the furnace which feeds the transformers for the furnace and the humidifier and the zone controller and all the zone actuators. I guess I could recheck that wiring but I don't understand how that could be the problem if flipping this switch off and then back on fixes my problem.
#4 |
An old Tradesmen
Loose wire in the box the switch is in. May have bumped the ground wire that it isn't making contact like it should all the time after the furnace runs for a while(mild vibration can cause this).
#5 |
Well its been running fine since the last AC cycle a few days ago and I haven't touched anything. I find it hard to believe the problem is a loose wire. Something tells me this is not going to be a fun one to debug if the problem happens again.
| Display Modes | |
| gas furnace efficiency, hybrid heat pump, and payback times | av-geek | HVAC | 1 | 06-22-2012 08:46 AM |
| 3 - flash code, american standard freedom 90 furnace | dfferg | HVAC | 25 | 03-05-2012 12:21 AM |
| American standard heat pump question. | SS laser | HVAC | 5 | 01-04-2012 10:35 PM |
| VisionPRO Setup Functions & Heat Pump | infoskr | HVAC | 31 | 03-18-2010 02:15 PM |
| Ruud heat strip furnace blower | TKELLY | HVAC | 4 | 03-08-2010 03:09 PM |
