American Standard Furnace-2 Flash - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 09:58 PM   #1
Unhappy
American Standard Furnace-2 flash
Furnace runs fine for hours then only blows cold air. The burners light, then go out after 2 seconds. After several attempts to light, the 2 flash starts & the blower keeps going. Only way to get it to stop is to turn off at the switch. After it is off overnight, in the morning it will start & operate normally for many hours, then the same problem.
Vents are not blocked, filter is clean, I increased the intake by about 60% this summer by adding duct & vents.
HVAC tech will not come out unless it is in error mode, but with night temps at 8 degrees, I'll freeze if I keep it blowing.
Any suggestions? Simple parts to replace?
American Standard Furnace, 4 years old, Freedom 80, Comfort R, 2 stage
flocke is offline   Reply With Quote
Old 12-09-2009, 11:11 PM   #2
Houston204's Avatar
Rewards Points: 556
Clean your flame sensor.
Houston204 is offline   Reply With Quote
Old 12-10-2009, 09:16 AM   #3
2 flash error-Houston204
Houston , we have lift off! Thank you, it's nice & warm, furnace hasn't shut off since last night & it's zero outside! Thank you!
Tags
2 flash , american furnace , error codes
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-08-2011 11:33 PM
American Standard Freedom 80 Furnace not igniting all 4 burners chetw66 HVAC 2 09-25-2009 05:01 PM
American Standard or Comfortmaker Furnace jmff HVAC 16 05-03-2009 09:05 AM
American Standard Freedom 80 furnace weather_wolf HVAC 2 03-30-2008 08:50 PM
