American Standard Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 09:36 PM   #1
How do I fix 4 red blinking lights and blowing cold air when turned to heat
bugsz is offline   Reply With Quote
Old 04-20-2012, 09:38 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
You remove the doors of the furnace to reveal the legend which explains what the four flash code stands for, let us know and then we can tell you.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-20-2012, 09:49 PM   #3
okay, it says open limit device.....? i'm not sure what that means..
Old 04-20-2012, 09:52 PM   #4
oh thank you, we pulled the fuse and put it back in and its working now.! Thank you
Old 04-20-2012, 09:53 PM   #5
Wink
It's fixed now and blowing out warm air. thanks again!
Old 04-20-2012, 10:01 PM   #6
we work for tips.
Let us know if this happens again. A high temperature limit switch trips due to the furnace overheating. It's a safety device.
If it trips again it'll be due to an airflow issue such as a clogged/dirty return air filter or possibly even a dirty evaporator coil, maybe both.
Keep the filter in brand new condition if not brand new.
Thanks.
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
3 - flash code, american standard freedom 90 furnace bemaky HVAC 1 11-21-2011 03:12 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
american standard furnace casino1a HVAC 1 08-05-2011 12:36 AM
