American Standard Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 05:50 PM   #1
american standard furnace
My light is blinking 6 times, the blower is not working when unit is on, I believe the 6 blinks means "AC power reversed, poor grounding or system voltage too low, the unit is about 10 years old.
casino1a is offline   Reply With Quote
Old 08-05-2011, 12:36 AM   #2
REP
OK,I don't have the code list in front of me.If what you say is true then look for loose wiring in both the line and low voltage wiring.
If you have junction boxes between the breaker panel and the unit,then run a single line stright from breaker panel to the unit.Also make sure thebare wire is properly attached to the panel and to the furnace and the white and black wires are correct in the panel and where it attaches to the module in the furnace.With a meter check the line voltage for 120v.
With a meter check the transformer output.
You really need full power because when voltage gets to the flame sensor its so small that a minor drop in the supply will affect the sensor voltage.
REP is offline   Reply With Quote
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
American Standard 78 failure to light off Rjs6153 HVAC 8 11-08-2010 11:27 AM
American Standard Freedom 80 troubles johnmax HVAC 1 11-26-2008 12:43 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
