American Standard freedom 90 single stage - gas
check all your grounds in furnace. check from hot to ground and common to ground. If you have more than 10V from common to ground then you have a parts that is shorting to ground internally. ohm out the igniter ... sounds like a nitride igniter and should be between 10 -18 ohms. if everything checks ok... then probably a control board. lets take 1 step at a time though. let us know what you find.
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
