American Standard Freedom 90 Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 10:00 AM   #16
AKA HVACTECHFW
Rewards Points: 1,208
Originally Posted by chefpattyo View Post
I hav a American Standard Freedom 90 single stage and it just started tripping out when it calls for heat but I dont see any light codes.Tonight It started and I noticed it was running but blowing ice cold air.I just had the tanks filled this week .Could this also be the sensor your talking about that I need to clean and where is it located?
Patty
The flame sensor is in the burner compartment this picture is sideways. The flame sensor looks like this.
the flash code is located here.
BTW.... Trane and American Standard are the same
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-26-2011, 02:22 PM   #17
HVAC Tech
Ducthunter's Avatar
Patty
Sounds like it's tripping a safety switch, chk your filter if it's really dirty it could trip the hi limit. If it tripped a rollout switch near the burners call a professional out you may be having problems with proper draft
Ducthunter is offline   Reply With Quote
Old 03-28-2011, 06:31 PM   #18
@Ducthunter It does this one out of 4 times it calls for heat .I can hear the furnace kick on with gas and then go out.It will retry a few more times then start to blow heat.All filter are clean and unit is vacuumed out.Its very clean.
chefpattyo is offline   Reply With Quote
Old 03-28-2011, 06:48 PM   #19
AKA HVACTECHFW
did you clean the flame sensor?!
IT IS WHAT IT IS
Old 03-29-2011, 05:35 PM   #20
I know the original post was a long time ago, but it's still a relatively easy fix if you are at all gas furnace savvy. The flame sensor should be cleaned annually, as well as the crossover ports on the burner assembly. If the flame doesn't make it to the end burner the flame sensor will do it's job and shut the valve down.
brandonmcginnis is offline   Reply With Quote
Old 01-03-2013, 11:06 AM   #21
1993 model Freedom 90 - 4 flash code
I have a 1993 Freedom 90 that will not light and is giving me a 4- flash code Thermo protection open. Any idea how to repair that?
jeff935 is offline   Reply With Quote
Old 01-03-2013, 06:08 PM   #22
An old Tradesmen
Rewards Points: 7,372
Is or was the air filer dirty. may need a new limit.
Old 01-04-2016, 04:51 PM   #23
Rewards Points: 2
I have a four year old American Standard Freedom 90 single stage. After running through all the obvious diagnostics (thermostat batteries good, yes power, yes gas, furnace system board reset, high limit switch, rollout switch, igniter continuity, flame sensor) I had to call a tech.
Symptoms - igniter comes on but won't light. Should have guessed the gas valve when I didn't hear it click after igniter as described elsewhere.
The gas valve had crapped out. Didn't think to ask if there was condensate / particulate in the gas line trap, but a charitable explanation is this might be what killed it.
Very frustrating on a 4 year old furnace, doubly so since it happened on a cold January 1 and we had to wait 3 days for an affordable service call (no, the system board computer does not know the date ). As a former Houstonian, next time I pass through Tyler, TX I'm going to say a swear word.
aurum79 is offline   Reply With Quote
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
American Standard freedom 90 3 flash code t_cel HVAC 1 12-23-2007 05:38 PM
Questions about American Standard Products bhpizza HVAC 5 06-12-2007 08:36 PM
American Standard or Carrier? lilvree HVAC 1 02-09-2006 07:57 AM
American Standard vs. any other brand can'tdecide Plumbing 2 10-05-2004 06:54 AM
