American Standard Freedom 90 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 06:03 PM   #1
american standard freedom 90 problem
I have an american standard freedom 90 that keeps going into error code 3 which is a pressure switch lockout code and won't allow the furnace to restart. Any suggestions or solutions to this issue?
CAMERON12 is offline   Reply With Quote
Old 02-02-2011, 06:27 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,266
Check the intake and exhaust pipes outside for blockage. Stick your fingers inside them to be sure no snow or debris has got sucked in there.
Old 02-02-2011, 06:30 PM   #3
Originally Posted by yuri View Post
check the intake and exhaust pipes outside for blockage. Stick your fingers inside them to be sure no snow or debris has got sucked in there.
thanks! I did check the vent and intake. All clear. Any other suggestion?
Old 02-02-2011, 06:33 PM   #4
Hvac Pro
yuri's Avatar
How old is this furnace. Have you had it professionally serviced once a year. The condensate trap may be dirty and not draining the water from the heat exchanger. Does the exhaust fan inside the furnace run when you turn the heat up. If not then that is the problem.
Old 02-02-2011, 06:41 PM   #5
how old is this furnace. Have you had it professionally serviced once a year. The condensate trap may be dirty and not draining the water from the heat exchanger. Does the exhaust fan inside the furnace run when you turn the heat up. If not then that is the problem.
three years old. The exhaust fan does run when i turn up the thermostat. Condensate trap clean.
Old 02-02-2011, 06:54 PM   #6
"HVAC Pro"
seatonheating's Avatar
Call an HVAC contractor to perform maintenance. Money well spent and you'll have a nice, warm home.
seatonheating is offline   Reply With Quote
The Following User Says Thank You to seatonheating For This Useful Post:
CAMERON12 (02-02-2011)
Old 02-02-2011, 06:59 PM   #7
Hvac Pro
yuri's Avatar
Should have a 5 yr warranty on parts and you may want to call a Am Std. tech. If you mess with it then problems could arise. May have a faulty pressure switch or other problem which a tech with a manometer needs to check.
Old 02-02-2011, 07:06 PM   #8
should have a 5 yr warranty on parts and you may want to call a am std. Tech. If you mess with it then problems could arise. May have a faulty pressure switch or other problem which a tech with a manometer needs to check.
thanks for your advise.
American Standard Freedom 90 Question bobjbc HVAC 22 01-04-2016 04:51 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
american standard freedom 80 a/c issues bigshanemac HVAC 1 06-30-2010 03:49 PM
American Standard freedom 90 tokio_mx3@yahoo.com HVAC 2 06-01-2008 09:19 PM
American Standard Freedom 90 help. JEVSkeeter HVAC 1 03-25-2008 09:26 PM
