Old 02-11-2012, 04:55 PM   #1
American Standard Freedom 90 problem
I have an American Standard Freedom 90 furnace, the ignitor, seems to not always work, and now stopped al-together. I bought a new ignitor and replaced it, but still it doesn't glow to start a flame. The Blower recycles every 5 miniuts. What other problem may I be facing? Theres no flash codes. Thanks
MichaelC is offline   Reply With Quote
Old 02-11-2012, 05:01 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Is the inducer motor running,pressure switch closing?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-11-2012, 05:04 PM   #3
HVAC Tech/ Browns Fan
Is there water trap in the draft motor?
Tator1076 is offline   Reply With Quote
Old 02-11-2012, 05:09 PM   #4
how
A real call for heat that doesn't result in ignition should result in a led diagnostic code. If it doesn't, it ususally means that there hasn't been a real call for heat (Thermostat or thermostat wiring problem) or its a board problem.
Telling us if the inducer motor is running when the igniter isn't working helps point out which is which.
how is offline   Reply With Quote
Old 02-11-2012, 05:12 PM   #5
I have prophane gas coming in, but the igniter doesn,t light up.
Old 02-11-2012, 05:16 PM   #6
been there done that
well, since there is NO code flashing.....i am thinking its a bad board, if it was any other component I am almost positive it would be flashing a code.
dosy777 is offline   Reply With Quote
Old 02-11-2012, 05:16 PM   #7
Is the inducer motor the blower that vents to the outside? And what do you mean about water trap in the draft motor? Thanks
Old 02-11-2012, 05:18 PM   #8
how
Is the led light lit but just not blinking or is it off? I do run into boards with a dead led light which throws a wrench into on line diagnostics.
Old 02-11-2012, 05:23 PM   #9
plummen's Avatar
Yes the inducer motor vents the flue gas out through the pipe
Old 02-12-2012, 11:33 AM   #10
If drain is plug it will cause water to back up into the draft motor. There is a tan 90 vinyl elbow on that goes from draft motor then into clear tubing. If that elbow plugs up it will back up water.
Old 02-12-2012, 11:53 AM   #11
Professional
Often times the flash code can be hard to see through the window. A better way to check it would be to remove the blower door and tape the door switch so that the control still has power. Next verify that there is no flash code.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
American Standard Freedom 90 Question bobjbc HVAC 21 01-03-2013 07:08 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
American Standard Freedom 80 blowing cold air robertlmills HVAC 12 11-28-2011 10:35 AM
3 - flash code, american standard freedom 90 furnace bemaky HVAC 1 11-21-2011 04:12 PM
American Standard Freedom 90 Jd2009 HVAC 0 05-13-2010 11:35 AM
