#1 |
American Standard freedom 90 limit control
I have a American Standard 90 two stage that starts the main blower at or around the same time the gas lights. I understand there are dip switches that controls this, but in what configuration. The upper one has two switches and is labeled sw 1, the lower has three switches and is labeled sw 2. I would like it get at least a little bit warm before the blower starts.
Thanks |
#2 |
An old Tradesmen
Look in the install manual if you have it.
#3 |
Hvac Pro
Did you install a new thermostat recently? If so it may be set for electric heat and starts the fan instantly. Usually there is a switch on the back of it E or G. Put it to G (gas) or check the programming info.
#4 | |
An old Tradesmen
American Standard freedom 90 limit controlQuote:
That yuri. He's on the ball. I didn't think about that. |
#5 |
You sir are a genius, it was the tstat.
Thanks again |
#6 |
Hvac Pro
American Standard freedom 90 limit control |
| Display Modes | |
| 3 - flash code, american standard freedom 90 furnace | dfferg | HVAC | 25 | 03-05-2012 12:21 AM |
| Help with an American Standard Freedom 80 Furnace | cschwer | HVAC | 21 | 02-09-2011 12:33 AM |
| American Standard Freedom 78 issues. Please help. | kporter5414 | HVAC | 2 | 10-20-2010 08:14 AM |
| american standard freedom 80 | KEITH112 | HVAC | 5 | 11-12-2008 01:20 AM |
