American Standard Freedom 90 Help. - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2008, 07:13 AM   #1
American Standard Freedom 90 help.
Just found this forum and thank you in advance for your help.
First my problem started out as a stupid mistake. I travel and my wife let the propane tank go empty. Sunday night guess what no heat. I called the service company who came in replaced the valve, said it was leaking as they smelled gas, replaced the sensor said my was bad, replaced the drain hose, then told me I was out of gas.
Now the furnace will not light up everytime. It goes on a time or two then will not light and just runs the blower. I have to go power down the furnace, then it seems to work for a while.
I am getting a two flash code which reads external lockout. Any suggestions or help. Did I just get taken for 479 bucks?
Thanks again.
JEVSkeeter is offline   Reply With Quote
Old 03-25-2008, 10:26 PM   #2
Here's the latest.
Furnace guy says problem is the propane pressure. Propane guy says not so, must be air in the lines and is coming out to bleed them in the morning.
I call the furnace guy back and ask for my gas valve that was removed be returned to me. Surpise, went out in the trash today.......
Looks like an expensive lesson on who not to deal with and to check the gas levels.
American Standard Freedom 90 Question bobjbc HVAC 22 01-04-2016 05:51 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
American Standard freedom 90 3 flash code t_cel HVAC 1 12-23-2007 06:38 PM
Questions about American Standard Products bhpizza HVAC 5 06-12-2007 09:36 PM
American Standard or Carrier? lilvree HVAC 1 02-09-2006 08:57 AM
