American Standard Freedom 90 Fault Code Flashes 6 Times - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 05:04 PM   #1
american standard freedom 90 fault code flashes 6 times
what is causing this and how can i fix it
db1020 is offline   Reply With Quote
Old 01-13-2010, 05:16 PM   #2
An old Tradesmen
Rewards Points: 6,142
Look at the code legend on the inside of the blower panel door.
Old 01-14-2010, 12:37 PM   #3
not getting any power to thermostat or ignitor how can it be fixed
Old 01-14-2010, 01:54 PM   #4
An old Tradesmen
Ignitor won't get power if thermostat doesn't get power.
Check if it has power coming from transformer.
Old 01-14-2010, 02:36 PM   #5
An old Tradesmen
I trashed your other thread about the same problem.
pleas don't make multiple threads about the same problem. Thank you.
Old 01-14-2010, 06:56 PM   #6
ok my bad had a servicer come out and he said i need a blower motor is there a place i can get it online
American Standard Freedom 80 troubles johnmax HVAC 1 11-26-2008 01:43 AM
American Standard Freedom 90 4 flash code Gromit HVAC 1 11-25-2008 10:56 AM
Pressure Switch Problem? American Standard Pack Unit jaymel HVAC 4 10-20-2008 06:10 AM
American Standard Freedom 80 Kenneth L HVAC 3 10-17-2008 12:28 AM
American Standard Freedom 80 furnace weather_wolf HVAC 2 03-30-2008 09:50 PM
