Old 01-30-2011, 08:28 PM   #1
American standard freedom 90 error code
I'm getting an error code on my american standard freedom 90 of 3-flashes indicating pressure switch problem. I have blown through the hoses and get it to work for a few days and then the furnace goes out again. It's happened several times now. Are there any recommendations or solutions out there?
CAMERON12 is offline   Reply With Quote
Old 01-30-2011, 09:19 PM   #2
Condensate lines running slow can cause intermittent pressure switch errors.
The Following User Says Thank You to Marty S. For This Useful Post:
CAMERON12 (01-31-2011)
Old 01-30-2011, 10:33 PM   #3
ok first of all a pressure switch code doesnt refer to water in the condensate lines ,it refers to possible water, or another restriction in the exhaust pipes. soooo 1 be sure there are no obvious restrictions on the exterior venting. 2 check and make sure you have at least quarter inch per foot sloping on your vent pipes,and they are not holding water anywhere.chop chop good luck
DELTA.T4935 is offline   Reply With Quote
The Following User Says Thank You to DELTA.T4935 For This Useful Post:
Old 01-30-2011, 10:44 PM   #4
Professional
first of all it could be a slow condensate line that would cause this as : if the condensate backs up in to the inducer it will cause the pressure switch to trip.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-09-2011 12:33 AM
American Standard Freedom 78 issues. Please help. kporter5414 HVAC 2 10-20-2010 08:14 AM
american standard freedom 90 neight HVAC 4 04-29-2010 04:42 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 06:01 PM
American Standard Freedom 80 troubles johnmax HVAC 1 11-26-2008 01:43 AM
