-   -   American standard freedom 90 error code (http://www.diychatroom.com/f17/american-standard-freedom-90-error-code-94042/)
CAMERON12 01-30-2011 07:28 PM
I'm getting an error code on my american standard freedom 90 of 3-flashes indicating pressure switch problem. I have blown through the hoses and get it to work for a few days and then the furnace goes out again. It's happened several times now. Are there any recommendations or solutions out there?
Marty S. 01-30-2011 08:19 PM
Condensate lines running slow can cause intermittent pressure switch errors.
DELTA.T4935 01-30-2011 09:33 PM
ok first of all a pressure switch code doesnt refer to water in the condensate lines ,it refers to possible water, or another restriction in the exhaust pipes. soooo 1 be sure there are no obvious restrictions on the exterior venting. 2 check and make sure you have at least quarter inch per foot sloping on your vent pipes,and they are not holding water anywhere.chop chop good luck
hvactech126 01-30-2011 09:44 PM
first of all it could be a slow condensate line that would cause this as : if the condensate backs up in to the inducer it will cause the pressure switch to trip.
