American Standard Freedom 90 Comfort-r Maintenance, Mine Isn't Working (PICS) - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 09:08 PM   #16
seems like this unit has never worked right even for 5 years
it seems to struggle to do something, not sure
listen to sound in video
http://youtu.be/b2fYT0TnCPI
keeps doing that cycle for 5 minutes
usually between 1 and 3 minutes it would eventually blow heat, but sometimes it would blow cold
now it only blows cold, never heat
jason_jm is offline   Reply With Quote
Old 12-19-2011, 09:08 PM   #17
looks like its time to call out a pro..........sorry
harleyrider is offline   Reply With Quote
Old 12-19-2011, 09:09 PM   #18
yep i think it was busted since day 1
thanks for all the help though
Old 12-19-2011, 09:32 PM   #19
I'm Your Huckleberry
Rewards Points: 2,270
is the ignitor coming on and if so is it staying hot until the gas valve opens? You'll hear a click from the gas valve when it does open.
I see you have some tools, you have a meter? Amps?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-19-2011, 09:33 PM   #20
ill put camera right next to it and record sounds.....
and no to meter and amps, my tools are more for pulling things apart
Old 12-19-2011, 09:36 PM   #21
A minute (pronounced my-knewt) crack in the ignitor will still allow it to glow if the baord is telling it come on BUT that not visible to the naked eye crack will interfere with the ignitors ability to stay on. I have recently come across this problem.
What you do is check amp draw on the wire of the ignitor as it glows and see if the amperage drops out even a split second before the gas valve opens. I fit does then that is why your system is not lighting, tries and tries again and then locks itself out.
And ignitors don't get better once cracked, they get worse.
Thanks.
Old 12-19-2011, 09:41 PM   #22
the reason the ignitors, ones with very small cracks which still allow them to turn on and get hot, drop out just before the gas gets to it is that as they get hotter once lit the crack expands, breaking continuity.
I'm betting this is your problem only because it was American Standard furnace that this problem occured on. I called an American Standard supply house technical support and they guided me through that diagnosis and fix!
Thanks.
Old 12-19-2011, 09:42 PM   #23
yah i have a pro scheduled 8am
lets see what he says
thanks
Old 12-20-2011, 12:20 AM   #24
Houston204's Avatar
Rewards Points: 556
7. RESET AFTER LOCKOUT
When the integrated control module has shut the
system down and gone into lockout, the system
must be manually reset before the unit will restart.
To reset, turn the system power off, then on, then
off and then on again within 30 seconds. This may
be done at the unitís power source or at the thermostat.
The system will not reset unless the procedure
off-on-off-on is completed within 30 seconds.
Houston204 is offline   Reply With Quote
Old 12-20-2011, 06:17 AM   #25
AKA HVACTECHFW
Rewards Points: 1,208
put everything back together and either post another video or describe in detail the sequence of events that happen with a call for heat. We know that there is a 2 flash but that could be due to a few things.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-20-2011, 01:31 PM   #26
HVAC Tech/ Browns Fan
Sorry Im late on the post again but the flute pipe has water trap in it. It maybe not a good slop back to the furnace or plugged up . I can hear it on the video.
Tator1076 is offline   Reply With Quote
Old 12-20-2011, 01:43 PM   #27
It maybe even be that black hose off draft motor plugged up.
Old 12-20-2011, 08:31 PM   #28
Main circuit board bad replaced under warranty
then 2nd problem water not being pumped out properly
all seems good now
was good crash course in furnaces for me
thx all hopefully someone else will find this thread useful down the line.
The Following User Says Thank You to jason_jm For This Useful Post:
Doc Holliday (12-20-2011)
Old 12-21-2011, 07:26 PM   #29
Houston204's Avatar
Rewards Points: 556
I hope the tech new how to reset the board and didn't replace a perfectly good control board when the problem was only backed up condensation.
The Following 2 Users Say Thank You to Houston204 For This Useful Post:
harleyrider (12-21-2011), hvactech126 (12-21-2011)
Old 12-21-2011, 08:49 PM   #30
no, he did a lot of tests with voltages, and issuing the board direct commands, and it was not responding correctly, i watched him.
when the new board went in, all the tests passed, then he dealt with the condensation problem
American Standard Freedom 90 Question bobjbc HVAC 22 01-04-2016 04:51 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
American Standard Freedom 90 problems...please help 4theEARTH HVAC 2 06-24-2011 08:34 AM
American Standard Freedom 90-No Heat pbrjtr1 HVAC 2 02-04-2011 10:28 AM
American Standard freedom 90 3 flash code t_cel HVAC 1 12-23-2007 05:38 PM
