American Standard Freedom 90 Codes - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 05:42 PM   #1
American Standard Freedom 90 codes
I have a Freedom 90 Furnace that is flashing a four code,
The flame lights, the exhaust blower kicks on, but the blower motor for the duct does not run. It says that the 4 flash code is a Thermal protection devise open
Can anyone help with this
Bskaggs560 is offline   Reply With Quote
Old 01-23-2011, 05:46 AM   #2
An old Tradesmen
Rewards Points: 7,808
Do you have and know how to use a multimeter? If so, see if your getting voltage to your blower motor.
Old 05-19-2011, 01:18 PM   #3
I'm having this same problem, and have figured it has to be the main board or the blower motor. I measured the leads going from the board to the blower motor when it's calling for the blower to come on. It ramps up from 0 and then peaks and holds around 80 volts. Shouldn't it be showing 115-120? If the blower motor was only getting ~80 volts would it spin slowly or not at all? Would it be safe to disconnect the blower motor from the board completely, and then "hot wire" the motor with 115v to test the motor?
phlach is offline   Reply With Quote
Old 05-19-2011, 04:02 PM   #4
An old Tradesmen
If you know how to wire correctly, its safe.
Old 05-19-2011, 04:57 PM   #5
Thanks. Maybe I'll try that. Can you confirm if typically the main board should be sending 115V to the blower? The board is a Wilson-Rodgers 50A65-475. If I've investigated properly, this exact board isn't made any more, but this one is a universal replacement. Is there ever a reason it should only send 80V to the blower? If not, then it seems I need to replace the board regardless of the blower motor condition. Would you agree?
Old 05-19-2011, 05:15 PM   #6
An old Tradesmen
It should send 110/120 volts to blower, not 80.
american standard freedom 80 wont blow doglover HVAC 6 04-16-2017 01:27 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-08-2011 11:33 PM
american standard freedom 90 neight HVAC 4 04-29-2010 03:42 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 05:01 PM
