Old 01-06-2010, 07:35 PM   #1
American Standard Freedom 90 Blower Problem?
Came home from work and the house smells like gas/burnt plastic. Went downstairs to check the furnace and I hear (a motor) running and the ventilation leading from the furnace is warm/hot to the touch. I am not an expert or even an amateur regarding furnaces but I would like to check a few things before I call the HVAC man and pay big bucks.
It seems the unit is working but the blower may not be or at least air is not being pushed in the vents. Is this what is causing the bad smell in the house? Heat being generated but not getting blown?
I have an American Standard Freedom 90 circa 1998. How do I remove the panel to check out. What safety precautions should I do before poking around?
Is there a schematic for my furnace model? Thanks for any advice. I apologize in advance for not asking pertainent questions as I simply do not know what to ask other than describe the situation.
Update: I went to thermostat and lowered the temperature. Furnace turned off. Went back and increased temp on thermostat and the furnace runs but again no air being pushed through the vents. Turned thermostat fan to on and again nothing. Is there a breaker switch on my furnace? If so where so I can check to see if that has been switched? Thanks.
Lighthouse is offline   Reply With Quote
Old 01-06-2010, 08:28 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I agree with you. Sounds to me also like the blower isn't kicking in for whatever reason.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 01-06-2010, 08:30 PM   #3
the Musigician
Check your breaker box to see it it's tripped first. If not, then I'd open the panel on the furnace and see if there is a reset button on the blower.
From there, well.... could be toasted blower motor, or any number of other things.
The guys here are pretty good, they'll get you fixed up most likely.
DM
Old 01-06-2010, 08:47 PM   #4
Thanks for the reply Danger. Is there a breaker on the furnace? or do you mean the main breaker for the house? I spoke with someone who will be coming out tomorrow evening. Gonna be a cold night LOL!! Anyway, it also sounded like the blower to this person too. He said if it is the blower then it can cost around $500 - $1000. Does this sound right?
Old 01-06-2010, 08:59 PM   #5
the Musigician
the house breaker panel, just see if it's tripped there first.
and some motors have a reset button on them, it could be that. set the switch on the thermostat to auto.
DM
Old 01-06-2010, 09:03 PM   #6
Nope the breaker was not tripped. Tried to look for reset button but only saw a button that caused a light to flash slowly. Looks like the HVAC man is coming in 30 minutes. Again if it is the blower is $500 - $1000 reasonable if it is the blower? American Standard High Efficiency Freedom 90 (1998). Thanks.
Old 01-06-2010, 09:03 PM   #7
An old Tradesmen
Could b the motor. or just a bad capacitor.
With power turned off. Look in the blower compartment. look for an oval canister. look to see if its bulged. if it is. Its bad.
If you have a VS blower. Then you won't have a capacitor.
Price of motor and to change it out varies greatly with area. And motor size and type.
Old 01-06-2010, 09:17 PM   #8
Burnt plastic smell could well be the circuit board fried.
Old 01-06-2010, 09:33 PM   #9
Hope not, but I think it is due to burner coming on and the blower not working but then again I am not an expert. A fried board does not sound good... keeping my fingers crossed as the tech should be here soon. After I get the diagnosis I will post to see who had the right answer hahaa....
Old 01-06-2010, 11:40 PM   #10
Okay here is the conclusion. HVAC tech came over at 9:00 pm and left at 11:15 pm so 2.5 hours of work. The smell in the house was generated by the blower motor due to being burnt out. The blower motor had to be replaced with a 3/4 hp motor. Apparently one of the bigger motors out there. Including the service fee to come out, total was $444.
Man what a night... Hope this can help out others who may come home to a house smelling like burnt plastic and cold air.
Old 01-07-2010, 05:55 AM   #11
An old Tradesmen
Plus his driving time.
And its an after hours call. Not a bad price.
Old 01-07-2010, 06:57 AM   #12
the Musigician
you mean I was actually RIGHT for once? wow!
DM
Old 01-07-2010, 07:02 AM   #13
An old Tradesmen
DM
LOL...
We're making you into an HVACer.
Old 10-11-2010, 11:07 PM   #14
Question
Gentlemen: I have the exact same furnace and problem, but a different cause. Our basement flooded with clean ground water about 18 inches, and we left the furnace alone to completely dry out. Now we try to start it, and everything works well, except that the blower never comes on. The heat builds up from the burners and turns itself off after about a minute or two. The lower half of the control board I know was under water, but feel that the real problem is the blower motor. Question: If a motor is under water for a day, can it be saved without buying a whole new motor?
ekimmo is offline   Reply With Quote
Old 10-12-2010, 04:39 AM   #15
An old Tradesmen
Seldom.
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
American Standard Furnace-2 flash flocke HVAC 2 12-10-2009 10:16 AM
Blower Motor Problem curranelectric HVAC 5 08-06-2009 07:04 PM
American Standard Freedom 80 furnace weather_wolf HVAC 2 03-30-2008 09:50 PM
Furnace Blower Problem SGecko HVAC 2 09-27-2006 11:16 AM
