American Standard Freedom 90 Blower Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 08:36 PM   #1
Question
American Standard Freedom 90 blower fan
I have an American Standard Freemdom 90 and the fan has started vibrating. I first thought it was just when the AC was on but I turned the fan from auto to on and still hear the vibration.
Is this usually the motor bearings or the cage off balance? How do you fix it?
Any help would be appreciated.
odesr is offline   Reply With Quote
Old 05-16-2012, 09:11 PM   #2
Rewards Points: 582
1st check to see if anything got in the blower wheel..paper,label for inside unit, mouse,,...happens sometimes...
Old 05-16-2012, 09:14 PM   #3
as seen on tv
Rewards Points: 150
Remove blower housing disassemble and pressure wash wheel. You will have to remove circuit board and wiring. Wire tie it out of way to for easy housing removal. Usually it is just crud built up in the wheel
qbert is offline   Reply With Quote
Old 05-16-2012, 11:44 PM   #4
REP
If a good cleaning doersn't fix it then you probably have a broken motor mount,a lose screw,or a balancing clip that has come off the blower wheel's fin.
REP is offline   Reply With Quote
Tags
american standard furnace
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
American Standard Freedom 90 problems...please help 4theEARTH HVAC 2 06-24-2011 08:34 AM
American Standard Freedom 90 Jd2009 HVAC 0 05-13-2010 10:35 AM
american standard freedom 90 neight HVAC 4 04-29-2010 03:42 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 05:01 PM
