-   -   American Standard Freedom 90 blower fan (http://www.diychatroom.com/f17/american-standard-freedom-90-blower-fan-144028/)
odesr 05-16-2012 08:36 PM
I have an American Standard Freemdom 90 and the fan has started vibrating. I first thought it was just when the AC was on but I turned the fan from auto to on and still hear the vibration.
Is this usually the motor bearings or the cage off balance? How do you fix it?
Any help would be appreciated.
ben's plumbing 05-16-2012 09:11 PM
1st check to see if anything got in the blower wheel..paper,label for inside unit, mouse,,...happens sometimes...:yes:
qbert 05-16-2012 09:14 PM
Remove blower housing disassemble and pressure wash wheel. You will have to remove circuit board and wiring. Wire tie it out of way to for easy housing removal. Usually it is just crud built up in the wheel
REP 05-16-2012 11:44 PM
If a good cleaning doersn't fix it then you probably have a broken motor mount,a lose screw,or a balancing clip that has come off the blower wheel's fin.
