Old 12-23-2007, 05:22 AM   #1
American Standard freedom 90 3 flash code
Hello,
Its 4 AM and my 10 day old furnace (single stage) is not working. It comes on with the startup cycle for about a minute and then shuts down. A few minutes later it will repeat this but it never fires up. Here is what is says in the manual for this error code:
Draft Pressure Error - Possible Problems:
a) Venting Problem
b) Pressure switch problem
c) Inducer problem
The pressure switch tube is clear and I just replaced the filter. There are high winds right now, it is possible this is causing some sort of venting problem? I will give my service guy a call in the morning but until then does anyone have an idea?
Thanks.
t_cel is offline   Reply With Quote
Old 12-23-2007, 06:38 PM   #2
Union HVAC Tech.
Call the installer back there is most likely a problem with the venting.
bigMikeB is offline   Reply With Quote
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Rheem vs American Standard Vicki HVAC 23 10-16-2010 03:44 AM
American Standard Freedom 90 2 flash Snowskibum HVAC 1 10-23-2007 02:42 AM
Questions about American Standard Products bhpizza HVAC 5 06-12-2007 09:36 PM
American Standard vs. any other brand can'tdecide Plumbing 2 10-05-2004 07:54 AM
