-   -   American Standard freedom 90 3 flash code (http://www.diychatroom.com/f17/american-standard-freedom-90-3-flash-code-14684/)
t_cel 12-23-2007 04:22 AM
Hello,
Its 4 AM and my 10 day old furnace (single stage) is not working. It comes on with the startup cycle for about a minute and then shuts down. A few minutes later it will repeat this but it never fires up. Here is what is says in the manual for this error code:
Draft Pressure Error - Possible Problems:
a) Venting Problem
b) Pressure switch problem
c) Inducer problem
The pressure switch tube is clear and I just replaced the filter. There are high winds right now, it is possible this is causing some sort of venting problem? I will give my service guy a call in the morning but until then does anyone have an idea?
Thanks.
bigMikeB 12-23-2007 05:38 PM
Call the installer back there is most likely a problem with the venting.
