Old 10-17-2010, 01:25 PM   #1
american standard freedom 80 wont blow
I have an american standard freedom 80 furnace. not sure of age. The blower wont run. Everything else seems to work fine. The code light flashes constant and fairly slow. Any ideas on what to check? I did turn motor shaft by hand with unit turned on and it took off but when I put door back on it would not continue to run. Im guessing it stop when I put door on and would not restart.
doglover is offline   Reply With Quote
Old 10-17-2010, 02:32 PM   #2
Hvac Pro
Does it run when you put the fan to ON at the thermostat. If you have to spin start it then it sounds like the capacitor is shot.
Old 10-17-2010, 02:54 PM   #3
Thanks for relpy. I have a programable thermostat. Will the fan run even if the thermostat is not set to heat or A/C? The cap is about 5 or 6 inches tall andoval? Right? How much are they? Thanks
Old 10-17-2010, 04:08 PM   #4
Hvac Pro
Should run if set to ON.
Yes. Should have a rating like 370 vac 5mfd or 7.5 or 10 mfd. Under $30.
Old 08-26-2011, 10:51 PM   #5
Where is the capacitor located? Thanks!
JBG420 is offline   Reply With Quote
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-09-2011 12:33 AM
American Standard Freedom 78 issues. Please help. kporter5414 HVAC 2 10-20-2010 08:14 AM
american standard freedom 90 neight HVAC 4 04-29-2010 04:42 PM
American Standard Freedom 90 Operation Question goodtexan HVAC 1 01-31-2010 06:01 PM
american standard freedom 80 KEITH112 HVAC 5 11-12-2008 01:20 AM
