American Standard Freedom 80 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 09:11 PM   #1
American Standard Freedom 80 furnace
Diagnostic light is flashing five times indicating " flame sensed with gas valve off". Fan runs with no call for heat and stops only when power is disconnected. Blower comes on with fan, but never sequences to ignition (hot surface igniter), no flame ever comes on so why should it indicate this problem? Could this be a bad module?
Tfrancis51 is offline   Reply With Quote
Old 11-22-2010, 11:27 PM   #2
Clean the flame sensor with steel wool or a scotch brite pad (do NOT use sand paper or even sand cloth).
hvac benny is offline   Reply With Quote
Old 11-23-2010, 04:21 AM   #3
An old Tradesmen
Rewards Points: 7,802
Was a new thermostat put on in the last year. if so, post brand an model number.
Was any electrical work done in your house in the last year.
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
American Standard Furnace Mystery David6 HVAC 37 01-30-2010 09:50 AM
american standard freedom 90 fault code flashes 6 times db1020 HVAC 5 01-14-2010 05:56 PM
American Standard or Comfortmaker Furnace jmff HVAC 16 05-03-2009 09:05 AM
