American Standard Freedom 80 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 09:35 PM   #1
American Standard Freedom 80 furnace
i've got two problems with this furnace. one-- it keeps shutting down on me. like it's shutting it's power off to itself. it's not breaking the breaker, the LED light is off and everything. i jiggle the circuit board around and it kicks back on. i'm thinkin it's something wrong with the board. and/or a loose wire.
two-- when it is working, occationally the flame will go out (i do have propane) and the LED light will flash 4 times fast then pause for a few seconds, then flash 4 more, etc. it's will still be blowing but it continues to try and light. i've replaced the glo plug already. and i don't have a list of what the LED flashes mean, on the back of my panel either. model number--ADD080C945C3 serial number--L394M891G
i think it's a 1993. and if andbody has the complete LED light flahes list.
weather_wolf is offline   Reply With Quote
Old 03-30-2008, 06:14 PM   #2
Rewards Points: 83
American Standard
Wolf,
I've got the same model. Purchased it in 2001 or 2002.
AMERICAN STANDARD FURNACE-LED LIGHT PROGRAM
Furnace LED Flash
Flash Slow Normal, no call for heat
Flash Fast Normal, call for heat
Continuous on Replace Control
2 Flashes External Lockout
3 Flashes Pressure Switch error
4 Flashes Open high limit >>>>>
5 Flashes Flame Sensed when no flames should be
Present
6 Flashes 115 AC reversed or poor grounding
7 Flashes Gas valve circuit error
8 Flashes Low flame sense signal
9 Flashes check ignitor
Best of luck with the furnace, rredogg
rredogg is offline   Reply With Quote
Old 03-30-2008, 08:50 PM   #3
thanks for that one, helps me out a bit.
American Standard Freedom 90 Question bobjbc HVAC 22 01-04-2016 04:51 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-04-2012 11:21 PM
American Standard Freedom 90 help. JEVSkeeter HVAC 1 03-25-2008 09:26 PM
American Standard freedom 90 3 flash code t_cel HVAC 1 12-23-2007 05:38 PM
Questions about American Standard Products bhpizza HVAC 5 06-12-2007 08:36 PM
