-   -   American Standard Freedom 80 furnace (http://www.diychatroom.com/f17/american-standard-freedom-80-furnace-19210/)
weather_wolf 03-29-2008 09:35 PM
i've got two problems with this furnace. one-- it keeps shutting down on me. like it's shutting it's power off to itself. it's not breaking the breaker, the LED light is off and everything. i jiggle the circuit board around and it kicks back on. i'm thinkin it's something wrong with the board. and/or a loose wire.
two-- when it is working, occationally the flame will go out (i do have propane) and the LED light will flash 4 times fast then pause for a few seconds, then flash 4 more, etc. it's will still be blowing but it continues to try and light. i've replaced the glo plug already. and i don't have a list of what the LED flashes mean, on the back of my panel either. model number--ADD080C945C3 serial number--L394M891G
i think it's a 1993. and if andbody has the complete LED light flahes list.
rredogg 03-30-2008 06:14 PM
American Standard
Wolf,
I've got the same model. Purchased it in 2001 or 2002.
AMERICAN STANDARD FURNACE-LED LIGHT PROGRAM
Furnace LED Flash
Flash Slow Normal, no call for heat
Flash Fast Normal, call for heat
Continuous on Replace Control
2 Flashes External Lockout
3 Flashes Pressure Switch error
4 Flashes Open high limit >>>>>
5 Flashes Flame Sensed when no flames should be
Present
6 Flashes 115 AC reversed or poor grounding
7 Flashes Gas valve circuit error
8 Flashes Low flame sense signal
9 Flashes check ignitor
Best of luck with the furnace, rredogg
weather_wolf 03-30-2008 08:50 PM
thanks for that one, helps me out a bit.
