Old 11-23-2009, 02:00 PM   #1
American Standard Freedom 80 Diagram?
Hi,
I think I need a parts location diagram. The LED is blinking 4 times. I found the codes and wiring diagram inside the panel but cannot locate the part "high limit device". I do not know what it looks like either.
The furnace model# AUD120C954K2.
The fan runs but there is no heat. I replaced the filter; they were totally clogged but no change. I am an electronics tech but not an electrician or HVAC tech. Any help appreciated.
Thanks, John
John Fraser is offline   Reply With Quote
Old 11-23-2009, 07:29 PM   #2
Limits are above the burners ,usually 12" or so up.
Old 11-24-2009, 12:09 AM   #3
Hi,
Could you please look at my attached picture and tell if I have identified the high limit switch correctly?
Old 11-24-2009, 07:35 AM   #4
The limit is above the two left burners in the picture, the brown rectange with two wires. Check it with your meter.
Old 11-24-2009, 08:33 PM   #5
Only limit switch I could find in my area was a universal adjustable for $60. Still, less than a service call and it works fine. Thanks again.
American Standard Freedom 90 Question bobjbc HVAC 21 01-03-2013 07:08 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Help with an American Standard Freedom 80 Furnace cschwer HVAC 21 02-09-2011 12:33 AM
American Standard Freedom 78 issues. Please help. kporter5414 HVAC 2 10-20-2010 08:14 AM
american standard freedom 80 KEITH112 HVAC 5 11-12-2008 01:20 AM
