Old 11-10-2008, 10:52 PM   #1
Question
american standard freedom 80
Hi, I have a american standard freedom 80 single stage furnance and the diag. led does not flash. The door interlock switch is closed and I am getting 120 at the line h and line n. The voltage at the transformer is 120 and on the backside i get 24. Is there more voltage checks I can make.
KEITH112 is offline   Reply With Quote
Old 11-11-2008, 12:29 AM   #2
Check the plug in fuse on the board.
Black Adder is offline   Reply With Quote
Old 11-11-2008, 12:44 PM   #3
Hey thanks for the reply, I did check the fuse and it ohm out good. The voltage on either side of it is at 24 volts. Are there other fusings.
Thanks Keith112
Old 11-11-2008, 12:54 PM   #4
That's the only fuse on the board, if everything else checks out good power wise. Sounds like it's time for a new board..
Old 11-11-2008, 11:12 PM   #5
thanks for the help. I found three bad solder connections on the circuitboard. I repair them and the system is up and running. The diag. LED is flashing normally, the led flashing a fault code for the pressure sensor is gone (three flashes). So far so good. I repaired the connection that has 12 connections (one big connection) the connection solder were 3,6,7 and 10.
Thanks for your help, Keith
Old 11-12-2008, 01:20 AM   #6
you go boy!!! most just toss and replace the board nice work
kennzz05 is offline   Reply With Quote
American Standard Freedom 90 Question bobjbc HVAC 21 01-03-2013 07:08 PM
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
American Standard Freedom 80 Kenneth L HVAC 3 10-17-2008 12:28 AM
American Standard freedom 90 tokio_mx3@yahoo.com HVAC 2 06-01-2008 10:19 PM
American Standard Freedom 80 furnace weather_wolf HVAC 2 03-30-2008 09:50 PM
