-   -   american standard freedom 80 (http://www.diychatroom.com/f17/american-standard-freedom-80-a-31609/)
KEITH112 11-10-2008 10:52 PM
Hi, I have a american standard freedom 80 single stage furnance and the diag. led does not flash. The door interlock switch is closed and I am getting 120 at the line h and line n. The voltage at the transformer is 120 and on the backside i get 24. Is there more voltage checks I can make.
Black Adder 11-11-2008 12:29 AM
Check the plug in fuse on the board.
KEITH112 11-11-2008 12:44 PM
Hey thanks for the reply, I did check the fuse and it ohm out good. The voltage on either side of it is at 24 volts. Are there other fusings.
Thanks Keith112
Black Adder 11-11-2008 12:54 PM
That's the only fuse on the board, if everything else checks out good power wise. Sounds like it's time for a new board..
KEITH112 11-11-2008 11:12 PM
thanks for the help. I found three bad solder connections on the circuitboard. I repair them and the system is up and running. The diag. LED is flashing normally, the led flashing a fault code for the pressure sensor is gone (three flashes). So far so good. I repaired the connection that has 12 connections (one big connection) the connection solder were 3,6,7 and 10.
Thanks for your help, Keith
kennzz05 11-12-2008 01:20 AM
you go boy!!! most just toss and replace the board nice work:thumbup::thumbup:
